" /> Can we route call on Basis of missing skill? - Genesys CTI User Forum
Author Topic: Can we route call on Basis of missing skill?  (Read 4819 times)
Offline abhaymisra
« on: January 05, 2008, 06:41:29 PM »
Hi All,
i want to route call on the basis of missing skill. Will Not (!) work in Skill Expression in a routing strategy?
e.g.
A>0 & B>1 & !C
Where A,B and C are 3 skills assigned to an agent. I want if Skill C is missing so call should go to different path.
Please suggest any solution for implementing the same.
Abhay Misra
Offline Daimonas
  • There's a fish in every bowl.
Re: Can we route call on Basis of missing skill?
« Reply #1 on: January 09, 2008, 08:52:39 PM »
Yes, you can do this as if you were to check for anyone will skill A=0, the result will be everyone who does not have skill A.
So your skill expression would look like:
A>0 & B>1 & C=0
« Last Edit: January 09, 2008, 08:54:12 PM by Daimonas »
Offline abhaymisra
« Reply #2 on: January 11, 2008, 01:12:57 PM »
Thanks for your reply...But my problem is little a bit different..
There are 2 agents say Agent1 and Agent2
Agent1 is having skill A=2,B=3 and Agent2 is having skill A=2,B=3 and C=2.
I want if a call is coming with the target expression A>0 & B>0 it should not go to Agent2.
Since we are using 2 types of skill expression
1. A>0 & B>0
2. A>0 & B>0 & C>0
So i want to prevent Skill Expression 1 call to go to Agent2.
Do you have any idea how to handle this situation.
Abhay Misra
Offline Kevin S
« Reply #3 on: January 11, 2008, 01:28:46 PM »
I haven't tried this, but try:
A>0 & B>0 & C=0
According to Genesys documentation, an agent with the Skill = 0 is supposed to be the same as the agent not having the skill.
You *MAY* need to give your Agents with just A & B skill Skill C and set C=0 for those agents.
dsanchez
« Reply #4 on: January 14, 2008, 03:58:56 PM »
add  to  Agent1 and Agent2 the skill c=0 and thescript
A>0 & B>0 & C=0
If the agent3 have the skill>0
Offline Daimonas
« Reply #5 on: January 17, 2008, 03:34:18 PM »
Wow alot of echos, didn't I already say this?
« Reply #6 on: January 17, 2008, 04:02:35 PM »
lol they just wanted to be sure he understood lol
