" /> Configuration Management - Genesys CTI User Forum
Author Topic: Configuration Management  (Read 3785 times)
Offline edobellamy
« on: January 08, 2008, 01:49:18 PM »
Hiya
I’m dealing with quite a few environments and is a pain to document all the deltas and differences between them. I’m wondering if there would be a sql tool to do this,
I’m thinking of a tool that Creates Listings of Applications, Ports, Connections, Users, etc and that you that could detect differences between a list of entities in different environments.
That could make the migration process run more smoothly. Has anybody heard or develop of such a tool ?
Cheers,
tony
Re: Configuration Management
« Reply #1 on: January 08, 2008, 03:25:34 PM »
The Configuration SDK .... ?
The Configuration Import Wizard ... ?
;D
Offline edobellamy
« Reply #2 on: January 08, 2008, 03:30:04 PM »
I was hopping of some sql based applciation that would allow me to see differences between environments and produce some readable documentation
tony
« Reply #3 on: January 08, 2008, 03:32:03 PM »
You could use the Configuration SDK to export settings in both environments to a flat file and compare the two...
If it's bespoke SQL you are looking for, I may need to move this Thread to the Developers Forum...
Tony
Offline edobellamy
« Reply #4 on: January 08, 2008, 04:08:40 PM »
I was hopping of some kind of tool to crate nice reports and diferences about environments form a single or few buttons  :)
« Reply #5 on: January 08, 2008, 05:27:41 PM »
Well as said you can create it
