I've managed my lab to have cfgdbserver primary and backup...
Here's the logs from cfgdbserver backup :
Genesys Database Server, Version:'7.5.000.07'
Copyright (c) 1997-2006 Genesys Telecommunications Labs, Inc.
Component versions:
Commonlib:        7.5.000.24 C2
Loglib:           7.5.000.04
Gmessagelib:      7.5.000.01
GServicelib:      7.5.000.04
Mngmlib:          7.5.000.00
Confservlib:      7.5.000.11
Lcalib:           7.5.000.05
Build platform:   i686-winnt
Application name: Backup_DBServer
Application type: RealDBServer (46)
Command line:     C:\GCTI\BackupDBServer\multiserver.exe -service DBServer_9 -host nxo-gexpress -port 2020 -app Backup_DBServer -cfg -c dbserver.cfg
Host name:        nxo-gexpress
DST:              TZ = 1, timeb = 0
Time zone:        -3600, Paris, Madrid, Paris, Madrid (heure d'été)
UTC time:         2008-01-08T20:41:41.171
Local time:       2008-01-08T21:41:41.171
Start time (UTC): 2008-01-08T20:41:41
Running time:     0:00:00:00
Host info:        Windows 5.2.3790, 2, Service Pack 2, 2.0, 0110, 3
File:             (1) C:\ExpressLogs\Backup_CfgDBServer\Bck_Cfg_DB.20080108_214141_171.log
21:41:41.171 Trc 04112 The Log Output of type 'C:\ExpressLogs\Backup_CfgDBServer\Bck_Cfg_DB' has been created and opened
21:41:41.156 Trc 04110 Option 'buffering' has been set to the value 'yes'
21:41:41.156 Trc 04110 Option 'spool' has been set to the value ''
21:41:41.156 Trc 04110 Option 'keep-startup-file' has been set to the value 'no'
21:41:41.156 Trc 04110 Option 'MessageFile' has been set to the value 'RealDBServer.lms'
21:41:41.156 Trc 04110 Option 'time-format' has been set to the value 'time'
21:41:41.156 Trc 04110 Option 'time-convert' has been set to the value 'local'
21:41:41.156 Trc 04110 Option 'message-format' has been set to the value 'short'
21:41:41.156 Trc 04110 Option 'memory-storage-size' has been set to the value '2 Mb'
21:41:41.156 Trc 04110 Option 'compatible-output-priority' has been set to the value 'no'
21:41:41.156 Trc 04110 Option 'print-attributes' has been set to the value 'no'
21:41:41.156 Trc 04110 Option 'check-point' has been set to the value '1'
21:41:41.156 Std 04106 Log Messages file 'RealDBServer.lms' successfully loaded
21:41:41.156 Trc 04112 The Log Output of type 'stdout' has been created and opened
21:41:41.171 Trc 04100 Logging service started
21:41:41.171 Trc 06084 Configuration option set: 'dbserver':'port' = '4060'
21:41:41.171 Trc 06084 Configuration option set: 'dbserver':'host' = 'nxo-gexpress'
21:41:41.171 Trc 06084 Configuration option set: 'dbserver':'management-port' = '4061'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'verbose' = '3'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'dbprocesses_per_client' = '1'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'dbprocess_number' = '255'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'dbprocess_name' = './dbclient_msql'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'oracle_name' = './dbclient_oracle'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'informix_name' = './dbclient_informix'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'sybase_name' = './dbclient_sybase'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'db2_name' = './dbclient_db2'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'msql_name' = './dbclient_msql'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'stored_proc_result_table' = '0'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'connect_break_time' = '1200'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'tran_batch_mode' = '0'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'reconnect_timeout' = '3600'
21:41:41.171 Trc 06085 Configuration option set to default value: 'dbserver':'client_stop_timeout' = '30'
21:41:41.171 Trc 06084 Configuration option set: 'lca':'lcaport' = '4999'
Open LCALayer on port=4999
LCA Library version 7.5.000.05
21:41:41.203 Std 05060 Application started
Open server port: = (
  "name" = "dbserver"
  "server-type" = "46"
  "port" = "4060"
21:41:42.171 Std 04525 Port 4060 opened for listening
LCALayer: REventRegistered on LCA...
Listener (port id = dbserver fd = 232) is being closed. Checking for clients on listener...
Listener with port id = dbserver has been closed and deleted from list of current ports. Number of db app connections affected: 0
21:41:42.171 Std 04560 [color=red][b]Warm Standby (backup) mode activated [/b] [/color]
