" /> Ocs is not unable to track agent status - Genesys CTI User Forum
Author Topic: Ocs is not unable to track agent status  (Read 3628 times)
vinodgujja
« on: January 09, 2008, 10:22:04 AM »
Hello All-
Ocs is not able to track the agent status, Agents are ready but it shows, waiting agents.
I observed, once we change the status of agent to "not ready" and then back to "ready" , OCS will send the calls to that agent.
Agents status work fine for inbound calls,Not able to figure it out whats wrong?
any ideas pls?
Marked as best answer by on Today at 08:31:34 PM
Offline Fra
Re: Ocs is not unable to track agent status
« Reply #1 on: January 09, 2008, 10:37:44 AM »
  • Undo Best Answer
  • It may depends on several factors..which version of OCS are you running? Could you post an excerpt of its log file?
    Offline Daimonas
    • There's a fish in every bowl.
    « Reply #2 on: January 09, 2008, 08:32:00 PM »
    I would recommend taking a look at the following options and thier defination in the OCS reference manual, as I think your problem most likely lies here:
    engaged_release_action=soft_call_work
    inbound_answer_action=soft_answer
    inbound_release_action=soft_call_work
    internal_answer_action=soft_answer
    internal_release_action=soft_call_work
    login_action=soft_not_ready
    login_ignore_queue=true
    outbound_answer_action=soft_answer
    outbound_release_action=soft_call_work
