" /> configuration manager installation problem - Genesys CTI User Forum
Author Topic: configuration manager installation problem  (Read 2779 times)
dink
« on: January 10, 2008, 11:49:27 AM »
we had a pc that had Configuration Manager 7.5 installed on it. I removed the CME via the control panel and tried to install version 7.2. The installation seems to work properly but I am not able to start it. I don't receive a logon screen but the standard message '....has encountered a problem .......'
any idea ?
Re: configuration manager installation problem
« Reply #1 on: January 11, 2008, 09:35:53 AM »
  • Hi Dink,
    Please check if Genesys Common Wizard Component Set are installed on the host. If the answer is yes then try to uninstall that package. CME uses it and theoretically it could cause your issue.
    BTW Have you made restart before installing CME 7.2 after you removed 7.5?
    René
    dink
    « Reply #2 on: January 15, 2008, 05:02:29 PM »
  • thx rene; it is clear
