" /> Change outbound field size - Genesys CTI User Forum
Author Topic: Change outbound field size  (Read 3501 times)
Offline daveg
« on: February 04, 2008, 05:02:53 PM »
Is there a way to change the length of an Outbound calling list field (eg from varchar 6 to 7)? You can't change it on the field, you can't rename the field, it looks as if I have to create a new field with a new name. As this field is used (hard-coded) by other programs using the database calling list tables this may have a serious knock-on effect. Ideally I just want to increase the size using the same name.  ???
Re: Change outbound field size
« Reply #1 on: February 04, 2008, 05:20:35 PM »
Go directly to the calling list table on the DB and modify it with an alter command. Remember only the change. If you create a new table with same format with small field you will have to redo the change.
Offline anisdz
« Reply #2 on: February 10, 2008, 11:05:23 AM »
Scream for a new calling list you need an table access that uses a Format to create a table
It is sufficient to change the format before shouting a new Table Acces
There must be general shout of table format for each type of compagn
Anisdz
Offline daveg
« Reply #3 on: February 22, 2008, 12:27:49 PM »
Thanks, cavagnaro, in this instance a new calling list is unlikely so the danger of changing it on the db and not remembering it when you create a new one is low. The only downside could be that you can't then populate the 9-digit db field using the 8-digit Genesys field definition with "update record" in OCM. Again, almost never to be used in this installation, so problem solved.
