" /> create a new contact in MCR when fax@corportate.com arrives - Genesys CTI User Forum
Author Topic: create a new contact in MCR when fax@corportate.com arrives  (Read 3554 times)
ahamd
« on: February 15, 2008, 02:52:57 PM »
Hi All
We have a fax email address .. evertime we get a fax from our fax@company.com we want MCR to put these email in a seperate work bins .. That ok . but as all faxes coming from same email address we would like to create new contact for each fax received e.g with the timestamp or some unique identifier
thank  you.
Regards
ahmad
Marked as best answer by on Today at 04:50:45 AM
Re: create a new contact in MCR when fax@corportate.com arrives
« Reply #1 on: February 15, 2008, 09:41:40 PM »
  • Undo Best Answer
  • Hi,
    I would say it's possible using IRD object "Identify Contact" but never used it.
    Could you please describe more in detail why you need to create a new contact for each incoming fax?
    René
    Offline Marco64
    « Reply #2 on: February 28, 2008, 11:31:32 AM »
    One solution, maybe not the best, I have seen working was to use a custom Customer's DB.
    Incoming faxes (emails) should carry the ANI and through this a sorting should be possibile.
    IE: If incoming fax is from Milan then it starts with 02_something if from Rome it starts with 06_something and so forth.
    in Pre-Routing you query the DB for known ANI's prefix and will route accordingly.
