" /> StayinFront integration with PABX - Genesys CTI User Forum
Author Topic: StayinFront integration with PABX  (Read 2902 times)
sshirazh
« on: February 20, 2008, 12:19:16 AM »
A client is interested in integrating to the StayInFront CRM package with a PABX. At this stage, there is no defined PABX although StayInFront integrates with a very few.
Is there any organisation which have done this before (preferably in Aust) and have any information with regards to integration as such.
Any information will be appreciated.
Marked as best answer by on Yesterday at 07:45:06 PM
Offline Adam G.
  • Still Gorgeous.......
Re: StayinFront integration with PABX
« Reply #1 on: February 20, 2008, 09:53:18 AM »
  • Undo Best Answer
  • Hi,
    I guess you're new to this forum, so welcome.
    From what you have said it sounds like you have a customer with a greenfield site and not much has been defined. The question that really sticks out is if you have Genesys (this is a Genesys forum  ;D )? I guess not as the PBX has not been defined.
    On a general level I'd therefore recommend you propose an Asterisk based soft-PBX and couple it with Genesys' SIP Server as this would give you a level of redundancy but at a reasonable price. The next step is to examine the StayInFront integration with Genesys. Genesys have a SDK for building the Genesys agent front-end into CRM\stand-alone apps. If you can find out from StayInFront how customizable their product is, and I'd hope it is, you could then get a custom module developed.
    I guess you were looking for someone to say [i]"I've done it and it was easy and here are some pointers"[/i], but I hope this has given you some pointers though.
    Drop me a line if you some more help on this.
    Pavel
