" /> Phone display shows "unknown" - Genesys CTI User Forum
Author Topic: Phone display shows "unknown"  (Read 5210 times)
Offline MarcRobinson
« on: February 20, 2008, 07:35:15 PM »
We have two call centers, each with two GVPs and two T-Servers. Routing is done by our PBXes (NOT by Genesys).
We have a problem when a call comes to the PBX at a call center and is given to a GVP, handled by the GVP for a while, and then given back to the PBX to be transferred to an agent. (The application basically does a flash-hook transfer to a 4-digit VDN, to give the call back to the PBX. The 4-digit value tells what skill to send the call to, and there's a descriptive string associated with it.) If the agent the PBX gives the call to is at the SAME site, the agent's phone display shows "unknown" (i.e., the descriptive string is missing). If the call gets bested (BSRed) over to an agent at the OTHER site, then the phone display shows the type of call -- e.g., "MO account inquiry".
The curious thing is that we haven't changed our IVR application. This started happening when we upgraded our Avaya PBXes from G3Rs to 8720s. When we used G3Rs, the phone displays worked.
Another curious thing is that when a call comes through the PBX directly to an agent, bypassing the GVPs, the screen display is correct.
And by the way, the screen pops show the correct call type -- it's only the phone display that shows "unknown".
I think the problem is clearly with the PBX (which is responsible for displaying the info about the call on the phone), but neither Avaya nor Genesys has any clue what's going on, so I'm asking whether anyone here has an answer, or at least any helpful advice.
Re: Phone display shows "unknown"
« Reply #1 on: February 21, 2008, 12:22:48 AM »
hum..unknown is when the SIP device is not identifying itself to the SIP Proxy, only authenticating, therefore the SIP Proxy sends unknown. If you check the SIP traces you will probably see:
sip:<gvp>@avaya <unknown>
Seems a problem on how the Avaya is handling the SIP headers.
« Reply #2 on: February 25, 2008, 06:26:54 PM »
It's not SIP -- we don't use it. We've got classic TDM T1s.
Another weird thing is that now some, but only some, of the calls at one site (but not the other) have started displaying the call type. In other words, at that site, some of the intrasite calls show the call type, and some don't. At the other site none of the intrasite calls show the call type on the agent's phone.
« Reply #3 on: February 25, 2008, 08:09:14 PM »
If your TServer logs shows the correct calltype then it's a PBX issue where maybe their discriminator is not correctly set. What does PBX guys say?
« Reply #4 on: February 26, 2008, 08:45:59 PM »
I do remember that we had similar issue to yours with Avaya switches. We got some text instead of routing point (VDN) number in case of multisite transfer. I was related somehow to Avaya "call-by-name" (or similar) feature. We had to modify routing to accept text because they couldn't switch it off as it will disable "call-by-name" feature for the users.
Unfortunately I don't remember more details...
René
« Reply #5 on: February 28, 2008, 06:15:32 PM »
Cavagnaro,
You're right: it's PBX-related. But Avaya hasn't been able to figure it out.
Rene,
Thanks for the tip. I think this will be useful. I'll forward it along.
