" /> Playing an announcement with GVP? - Genesys CTI User Forum
Author Topic: Playing an announcement with GVP?  (Read 3025 times)
Ben Taylor
« on: March 04, 2008, 10:55:42 AM »
Need a bit of help with GVP...
I've created a basic Script in Genesys Studio - all it does is play a Prompt and then Stop.
In VPM I've setup a new Voice Application and set the Primary Voice Application URL as the .asp for my new Script. Set the DNIS to my Test DTN (on Meridian this forwards to a CDN which is my Routepoint) and load a Strategy on that Routepoint that uses an IVR Treatment to target GVP (Compatible Mode: Script = 0, Target = GVP@Starserver.GP, Duration = null).
This works fine when I dial my DTN, but if I call the CDN directly it doesn't work as I have no DNIS...
How do I bypass all the DNIS stuff in VPM and just play the GVP Script directly?
Cheers,
Ben
Ben Taylor
Re: Playing an announcement with GVP?
« Reply #1 on: March 12, 2008, 02:55:29 PM »
  • Ended up setting attached data and using the Default Script...
