" /> CME Read Only alarm reaction - Genesys CTI User Forum
Author Topic: CME Read Only alarm reaction  (Read 3871 times)
Offline Tefleon
« on: March 19, 2008, 04:04:41 PM »
Hi.
Does anyone know of a method using SCI alarm reactions to put the Config Server into Read Only mode?
Cheers
Re: CME Read Only alarm reaction
« Reply #1 on: March 20, 2008, 11:04:57 AM »
There is a "solution" but I wouldn't recommend you using it... You can stop cfg_dbserver = ConfigServer goes to read only mode because of lost connection to the database.
René
Offline thicke
« Reply #2 on: March 20, 2008, 12:25:10 PM »
Rene - If you install the Configuration conversion Wizard on the Management Framework CD, it will put Config Server in read-only mode in order to do an export of the config database. That's probably a little safer.
« Reply #3 on: March 20, 2008, 12:52:30 PM »
Thicke,
You're right that your way is more safer then mine. But I don't see there is a possibility to script the wizard to switch ConfigServer to read-only mode = useless for alarm reaction that has to work automatically.
René
Offline Tefleon
« Reply #4 on: March 20, 2008, 01:31:15 PM »
I was hoping for something a little safer in terms of being able to put the config.server back into normal mode on an alarm too.
Cheers for the replies though
