" /> SAP CRM and gplus ICI adapter not compatible - Genesys CTI User Forum
Author Topic: SAP CRM and gplus ICI adapter not compatible  (Read 10210 times)
vinod
« on: April 04, 2008, 12:51:57 PM »
Hi All-
We have SAP CRM 5.0 and currently we are using gplus ICI adapter 7.5 in our Lab environment.
The problem we are facing is it seems ICI adapter 7.5 is not compatible with CRM 5.0 version it supports CRM 5.1(as per the document).
While making connection to genesys from SAP end(transaction SPHB)...creating telephony server...we get a error saying "Not compatible".
SAP guys dont have any plans to upgrade CRM to 5.1 as of now, is there any other way we can think of....
Didnt get any help from SAP support and genesys support :(
Can someone please provide me your inputs.
Re: SAP CRM and gplus ICI adapter not compatible
« Reply #1 on: April 06, 2008, 09:40:02 PM »
  • Vinod,
    Based on "Genesys 7 Supported Operating Systems and Databases Reference Manual" SAP CRM 5.0 is supported by Gplus Adapter for SAP ICI Multi-channel release 7.1.0 and higher. It requires SAP Service Pack 04 or higher to be installed. You can download mentioned document from Genesys Technical Support website
    Genesys Technical Support should be able to help you as you have supported version of SAP CRM.
    Have you tried older release (7.1) of Gplus adapter?
    René
    vinod
    « Reply #2 on: April 10, 2008, 08:59:04 AM »
  • Thanks Rene :)
    vinod
    « Reply #3 on: April 23, 2008, 12:26:38 PM »
  • Hi Experts-
    As per the deployment guide we need to make a Http connection from SAP.
    So in SAP RFC details we will mention 'GPLUS server and Port', thus SAP is aware which is the target but how does gplus will know where to target for SAP cos no where i see in config options the need to mention sap server details.
    Will the http connection is sufficient ? Please provide me ur views
    « Reply #4 on: April 24, 2008, 06:09:31 PM »
  • Hi Vinod,
    Yes, it's sufficient to specify Gplus adapter server and port of SAP side only. The communication is "unidirectional" - SAP IC calls Gplus adapter (HTTP request), Gplus processes the request and returns the output (HTTP response).
    vinod
    « Reply #5 on: May 05, 2008, 02:19:16 PM »
  • Many Thanks Rene
    svsergey
    « Reply #6 on: May 06, 2008, 01:19:19 PM »
  • Hi All!
    Gplus Adapter also sends http requests to SAP  :)
    WBW,
    Sergey.
    « Reply #7 on: May 06, 2008, 01:56:10 PM »
  • Hi Sergey,
    I assume you're talking about situation when SAP subscribes for agent/DN events (via SOAP Notification). In that case you're right and Gplus sends requests to SAP.
    Is that what you've meant?
    René
    svsergey
    « Reply #8 on: May 06, 2008, 09:38:29 PM »
  • Yes Rene, you are right. I meant "...Changed" events that Adapter send to SAP.
    Best Regards,
    Sergey.
    vinod
    « Reply #9 on: June 04, 2008, 12:31:17 PM »
  • Can we connect SAP CRM and genesys gplus thru RFC connection instead of http connection? Any ideas?
    ahmed
    « Reply #10 on: September 10, 2008, 08:27:52 AM »
  • Hi There , could someone please email documentation on the integration between Genesys CTI and sap CRM Webclient 5.0...
    ahmed@consnet.co.za
