" /> Avaya Genesys simple (prolly) question. - Genesys CTI User Forum
Author Topic: Avaya Genesys simple (prolly) question.  (Read 4586 times)
HowTo
« on: May 06, 2008, 12:02:58 PM »
Hello!
Just one question - probably dumb, but stuck at this point. When configuring options of TServer for AVAYA there is some fields in section link-tcp like "ip", "link number" & "port". The question is - what value for "port" should i use ?  I suppose it is a tcp port which should be administered in DLG application on MAPD. But i don't see any port administration in MAPD. Well I do understand how to do it with Alcatel where the standart port for TAPI exist ( 2555 as I remember). But what about AVAYA ?
Thanks in advance.
Reagrds,
HowTo.
Marked as best answer by on Today at 06:06:43 AM
Re: Avaya Genesys simple (prolly) question.
« Reply #1 on: May 06, 2008, 01:38:40 PM »
  • Undo Best Answer
  • Hi,
    Standard port is 5678. I haven't seen Avaya for a while so I don't remember where this port is configured on Avaya side... :(
    HowTo
    « Reply #2 on: May 06, 2008, 01:41:47 PM »
    Thanks a lot. Simultaneously found ot by myself. :) BTW I also dont't know how to change it using DLG. With Co-Res DLG it seems easy by administering ip-services form - but that is only for S8300.
    Offline bcyk
    « Reply #3 on: May 06, 2008, 03:03:16 PM »
    "brief" information on Avaya MAP-D and DLG configuration is attached (mapd-config.zip) for sharing.
    To configure ASAI-link, you need to configure objects in both switch and MAP-D.
    Have fun!
