" /> Genesys/Informiam solutions with Avaya CM? - Genesys CTI User Forum
Author Topic: Genesys/Informiam solutions with Avaya CM?  (Read 6136 times)
psdtel
« on: May 09, 2008, 06:50:57 PM »
After searching the Genesys and Informiam sites with little luck, I was hoping someone could answer a few basic questions.
-What Genesys/Informiam solution would you recommend for a small (less than 30 agents) contact center using Avaya Communication Manager? Right now am most interested in viewing real time stats like agent status/calls in queue/etc with ability to set thresholds, generate reports on agent and group performance (both real time and historical). No call recording needed. Would like both agents and supervisors to use the solution.
-Will multiple applications be needed (reporting, supervisor desktop, agent desktop, etc)?
-Budget is less than $10,000, will this be a problem?
Thanks for any insight!
Re: Genesys/Informiam solutions with Avaya CM?
« Reply #1 on: May 09, 2008, 08:23:24 PM »
Welcome to this board.
First of all Genesys can do a lot to help you but it will be much more of what you expect. Basic Genesys (Inbound) has integrated reporting functionalities, RealTime with a component called StatServer, this will collect all stats you need and define, it's architecture is very flexible so you create what you need, not what Genesys wants you to see.
Historical Reports is also a consecuence of StatServer, another component (ETL) will extract this info and store it into a DB (MSSQL, Oracle, Informix, DB2, Sybase) from where you can use any BD client like Crystal Reports for example and build your own templates, or you can use Templates that Genesys already provide with BRIO, but again you build what you need, not what Genesys tells you to see. In this way you create the reports as you want them to be, as Crystal Reports, Brio is not a end user application ready to go, you will need some expertize and someone who builds this reports and end user will only click and select dats and ready to go.
Supervisor Desktop is a module of Agent Desktop (GAD) where the idea is to give the end users a unique interface, however for me, it is no match for a CCPulse (end user real time viewer).
With Genesys you have right to use URS (Universal Routing Server) on where you can do complex routing decisions for the agents including all the power of a CTI, like connecting to a DB before going to a customer, apply priorities to a call based on a field that the DB returns and select an agent with skills or a script to choose the best agent for that call.
You will also have GAD, as mentioned, a end user tool, basically for agents where they login and control their phone interactions. However this can be discarded if you develop or buy another Genesys compliant softphone.
Call Record is not an option of Genesys, you will need something like Nice or eTalk to achieve this and they can integrate with Genesys and use the data attached on a call to use that power too and record based on a value of those fields.
For the budget, depends, if you have a good contact with Genesys you can get a good discount and maybe do something. I believe, not confirmed, that you will maybe need more budget for this little monster ;D
psdtel
« Reply #2 on: May 12, 2008, 03:35:39 PM »
Thanks for the info cavagnaro! Of the components that you mentioned (StatServer, ETL, BRIO, GAD), which are included with Basic Genesys and which need separate licensing/need purchased separately? Does another application need to be bought that will monitor outbound calls?
Marked as best answer by on Today at 01:47:08 PM
« Reply #3 on: May 12, 2008, 05:25:42 PM »
  • Undo Best Answer
  • no, all are "free" with CIM purchase, which is Genesys core.
    For outbound do you mean Genesys dialer (OCS) or manual outbound calls?
    On OCS you will use OCM to manage campaigns but any way StatServer and ETL will capture that data. You will be able to make statistics to for example on an agent distinguish between OCS outbound calls and agent manually dialed calls. What you can't do (:S) is to get stats on OCS with data, for example, for OCS dialed calls how many was from Type VIP, Gold, Bronze, etc. So far not an option...
    psdtel
    « Reply #4 on: May 12, 2008, 05:56:07 PM »
    The outbound calls would be manual, no dialer used.
    I am also interested in the Informiam contact center apps, do they work with Avaya Communication Manager? Any info on these apps (frontline advisor, historical analyzer, call analyzer) would be appreciated as well (good for a small contact center? all come packaged together or sold separately?).
    psdtel
    « Reply #5 on: May 15, 2008, 01:32:05 PM »
    « Reply #6 on: May 15, 2008, 02:25:21 PM »
    Well this is a Genesys forum, for what you are asking you may need to ask then local sellers near you. They will be able to provide more info.
    psdtel
    « Reply #7 on: May 15, 2008, 05:11:16 PM »
    I was hoping there would be some Informiam users here too since Genesys owns it now but I guess not
    « Reply #8 on: May 15, 2008, 05:47:19 PM »
    Well the adquisition was made on december of 2007, so I doubt any Genesys ready product is on market already...
    http://www.genesyslab.com/news/archives/2007/december/informiam.asp
    I will wait more time or maybe someone of Genesys (Paul?) has something to comment...
