" /> Restart WatchDog on IServerClient box Unable to find - Genesys CTI User Forum
Author Topic: Restart WatchDog on IServerClient box Unable to find  (Read 3641 times)
Abe
« on: May 27, 2008, 05:38:23 PM »
Genesys in their tech support suggested the following after adding a new attribute
using EMPS tree .
I could not find this RESELLER->CUSTOMER->GQA ?  What am I missing here ? Please help !
Restart WatchDog on IServerClient box (the one with process <Reseller>-<Customer>-GQA). Check if you now can access the Framework ConnID instead of UUID.
Marked as best answer by on July 28, 2025, 01:21:19 AM
tschoi
Re: Restart WatchDog on IServerClient box Unable to find
« Reply #1 on: May 27, 2008, 11:01:44 PM »
  • Undo Best Answer
  • Hi
    You should replace <Reseller>-<Customer> with the name of the actual reseller and customer defined in EMPS. Basically they are suggesting that you restart Watchdog on the machine where IServercliet(=GQA) is running.
    Regards,
    Taisuk
