" /> IVR Tserver application options tab in CME - Genesys CTI User Forum
Author Topic: IVR Tserver application options tab in CME  (Read 3306 times)
Raj
« on: May 29, 2008, 02:44:58 PM »
I am trying to follow what Genesys has suggested here but unable to find TServerClientSap. I am new to Genesys. Appreciate your help.
You need to change the following option in the IVR Tserver application options tab in CME In section [TServerClientSap]
defer-tlib-events = 'false' --> Please change to "True"
Offline S
Re: IVR Tserver application options tab in CME
« Reply #1 on: May 29, 2008, 05:01:16 PM »
  • Well check the options for IVR_TServer , if not there, create that section- it should be pretty easy to find :-\
