" /> Multi-channel integration and Unified Communications - Genesys CTI User Forum
Author Topic: Multi-channel integration and Unified Communications  (Read 4207 times)
Gitanjali
« on: June 05, 2008, 12:45:46 PM »
Hi ,
Can u please list the difference between Multi-channel integration and Unified  Communications .
Multi-channel integration deals with integration of all media channels.
Unified  Communications  deals with integration integration of disparate communications systems, media, devices and applications ( UM -unified messaging, One number for all devices ...) & stream lining data on IP
Thanks in advance
Marked as best answer by on Today at 07:31:28 PM
Re: Multi-channel integration and Unified Communications
« Reply #1 on: June 05, 2008, 05:15:01 PM »
  • Undo Best Answer
  • Unified Messaging is the concentration of several applications to one end user, maybe a normal user or maybe an agent, however this is not Multichannel where the CTI will integrate with services like email, chat, web, fax and receive customer interactions on that way.
    In Multichannel you will need several TServers which you can use to route the incoming information for making routing decisions and the agent can catch them as well.
    On Unified Communications there is no obligation of an CTI or similar, it is handled entirely by the end user at his will.
    « Reply #2 on: June 06, 2008, 02:10:41 AM »
    Cavagnaro,
    so, with multi-channel Genesys does all the thinking and routing, but in unified all of them are indistinguishable inside Genesys and are separated at user level? I always thought they were both the same thing!!!
    « Reply #3 on: June 06, 2008, 03:51:30 PM »
    yes Vic that is correct. I know definitions are very similar but the main difference between them if where they apply. Unified Messaging is more for use of administrative people rather than agents who need "something" to find them when available like a Genesys CTI
