" /> After first NOINPUT or NOMATCH GVP is not responding - Genesys CTI User Forum
Author Topic: After first NOINPUT or NOMATCH GVP is not responding  (Read 3581 times)
Raj
« on: July 09, 2008, 11:13:25 PM »
I have very simple form in which I have <NOINPUT COUNT="1"> and <NOINPUT COUNT="2">.
After I get the initial prompt and then if I  did not speak, it is throwing NOINPUT for the first time. After that again if I did not resond then that call is simply sitting just like that. If I purposefully hang-up the call and redial that port , that port is not responding . Sounds like it got hosed up. If I restart WATCHDOG then  that port becomes available to take the calls. So weired.
I am wondering what might be preventing GVP not to throw NOINPUT when count=2
Same thing  is true for NOMATCH as well. Appreciate if any one can help me.
Re: After first NOINPUT or NOMATCH GVP is not responding
« Reply #1 on: July 10, 2008, 05:30:34 AM »
Is this with VCS or IPCS? Behind or Infront?
Can you post at least some logs and maybe a screenshot of your application and how is it configured?
Raj
« Reply #2 on: July 10, 2008, 09:20:38 PM »
Thanks Cavagnaro. We are using VCS and behind mode. Would you please send me your email to ivr_genesys@yahoo.com  so that I can send you the logs. Thanks.
Marked as best answer by on Today at 06:10:36 AM
« Reply #3 on: July 10, 2008, 09:40:44 PM »
  • Undo Best Answer
  • Please post them here indicating the number dialed, originating number and hour, in that way we all will be able to help.
