" /> Help with call flow in genesys, the call hangup - Genesys CTI User Forum
Author Topic: Help with call flow in genesys, the call hangup  (Read 8689 times)
lcastillo
« on: July 11, 2008, 04:11:53 PM »
Hi, all.
I'm checking for a problem in a Call Center, some call are distribute and when a agente answer the call, the call hangup.
I need to check if the problem is in Genesys or in PBX, I check the t-server log and URS log, but don't find the problem.
Could u help me?
Attach are the URS and t-server logs-
lcastillo
Re: Help with call flow in genesys, the call hangup
« Reply #1 on: July 11, 2008, 04:51:28 PM »
  • I forgot, in the logs, the ConnID for the call that haungup is 006601967deab957
    « Reply #2 on: July 11, 2008, 05:18:50 PM »
  • Hum this is weird:
    @15:26:16.7120 [mlink] (processStatusChange)
    @15:26:16.7120 [mlink] (processScOnhook)
    @15:26:16.7120 [gctm] Call [006601967deab957/14e,s6,t7] distributing EventOnHook
    @15:26:16.7120 [gctm] Call [006601967deab957/14e,s6,t7] processOnHook
    @15:26:16.7120 [gctm] [color=red]Translate On-Hook to Released[/color]
    @15:26:16.7120 [gctm] Call [006601967deab957/14e,s6,t7] EventReleased delayed for party match.
    @15:26:16.8530 [<<] FF 0A 00 24 04 00 00 08 0F 00 37 04 20 88 36 08 00 08 36 30 36 31 38 03 05 96 06 00 00 01 4E 5F 05 0F 1A 2C
    Status Change
    This Device TN:2088
    This Device DN:Internal, 6061
    This Device Status:Disconnect
    Call ID:14e
    Enhanced Time Stamp:15:26:44
    @15:26:16.8530 [mlink] (processStatusChange)
    Can you explain a little bit how the call is arriving to your CC? Any IVR in the middle?
    Offline bcyk
    « Reply #3 on: July 11, 2008, 05:52:58 PM »
  • Tserver for Nortel Communication Server 1000 with SCCS/MLS, Version: 7.1.002.02 Compiled: Jul 28 2005 15:30:30
    ConnID = 006601967deab957
    DN (extension) = 6061
    [color=red]----> what is the Position DN for 6061?
            If and only if paired[b] Position DN of extension 6061 is 6091[/b],
            then, below suggestion makes sense and worth to try[/color]
    ============== truncated messages =======
    @15:26:12.7280 [0] 7.1.002.02 distribute_response: message EventEstablished
    AttributeThisDN '6061'
    AttributeConnID 006601967deab957
    AttributeCallID 334
    AttributeCallType 2
    @15:26:12.9150 [gctm] Party [006601967deab957:6061,sc,at1,r2,l1] EvEstablished ignored, already in Est. state
    @15:26:12.9150 [<<] FF 0A 00 1B 04 A1 C9 08 0A 00 30 08 00 00 36 30 36 31 71 03 00 96 06 00 00 01 4E
    [b]Answer Response[/b]
    Reference ID:21c9
    Origination Address:Unknown, [b]6061[/b]
    Result:[b]Successful[/b]
    @15:26:12.9150 [gctm] Address [6061,t1,s1] processOffHook
    15:26:13.197 Trc 04541 RequestAgentNotReady received from 740 (02d8 Desktop Toolkit 5.1 OLE/COM)
    message RequestAgentNotReady
    AttributeThisDN '6091'
    AttributeAgentWorkMode 0 (Unknown)
    AttributeReferenceID 10
    @15:26:13.1970 [tsgctm] Distributing request RequestAgentNotReady
    @15:26:13.1970 [mlink] AgentLogin [6091,id0039,s2] (reqAgentNotReady)
    Not Ready
    Reference ID:21ca
    [b]This Device DN:Unknown, 6091[/b]
    [b][color=red] No Call Disconnect:0[/color][/b]
    @15:26:16.7120 [<<] FF 0A 00 24 04 00 00 08 0F 00 37 04 20 88 36 08 00 08 36 30 36 31 38 03 01 96 06 00 00 01 4E 5F 05 0F 1A 2C
    Status Change
    This Device TN:2088
    This Device Status:On-Hook
    Call ID:14e
    @15:26:16.8530 [gctm] Call [006601967deab957/14e,s6,t7] distributing EventReleased
    @15:26:16.8530 [gctm] Call [006601967deab957/14e,s6,t7] EventReleased ignored, already have release.
    ===================== check T-server option "[b]no-call-disconnect[/b]"
    set it to [b]3[/b] in Genesys 7.1 T-server for NCS1000
    no-call-disconnect
    Default Value: 0 (All current calls are disconnected)
    Valid Values:
    0 All current calls are disconnected.
    1 Current ACD calls are not disconnected.
    2 Current DN calls are not disconnected.
    [color=red][b]3 Neither ACD nor DN calls are disconnected.[/b][/color]
    Changes Take Effect: Immediately
    Specifies the way the switch handles calls if the workmode parameter is set to
    AgentNoCallDisconnect in the TAgentSetNotReady function call. Globally sets
    the behavior for AfterCallWork.
    Note: If Agents use no-call-disconnect, Stat Server 7.0 or higher is required.
    good luck
    « Reply #4 on: July 14, 2008, 12:45:05 AM »
  • Hi, BCYK has it right:
    for Nortel, you need to set no-call-disconnect to 3 in order to not have your calls disconnected when you set your agent to not-ready after answering the call. I am sure there is a reasoning behind this atrocity, but I fail to see it.
    Try it and it shoudl take care of your problem.
    lcastillo
    « Reply #5 on: July 14, 2008, 03:52:51 AM »
  • Ok. I will check the no-call-disconnect and let you know any news
    Offline CTIgem
    « Reply #6 on: July 14, 2008, 01:18:54 PM »
  • By looking at your log,
    I see that "Request Agent Not Ready" is coming from your agent desktop...shortly after answering.
    Answer Response
    Reference ID:21c9
    Origination Address:Unknown, 6061
    Result:Successful
    Call ID:14e
    @15:26:12.9150 [mlink] (processAnswerResponse)
    @15:26:12.9150 [gctm] distributing EventEstablished to model
    @15:26:12.9150 [gctm] Call [006601967deab957/14e,s6,t7] distributing EventEstablished
    @15:26:12.9150 [gctm] Call [006601967deab957/14e,s6,t7] processEstablished
    @15:26:12.9150 [gctm] Party [006601967deab957:6061,sc,at1,r2,l1] processEstablished
    lcastillo
    « Reply #7 on: July 15, 2008, 09:13:49 PM »
  • Hi, I check all the option in tserver and don't find the no-call-disconect parameter,
    must I create it?
    attach is a image whit the options in t-server
    « Reply #8 on: July 16, 2008, 02:48:07 AM »
  • Yes, you must create it. Check the TServer doc and if says optional you may create it.
