" /> MAXIMUM Lines on a GVP-IP Standlone Box for SIP or ISDN PRI - Genesys CTI User Forum
Author Topic: MAXIMUM Lines on a GVP-IP Standlone Box for SIP or ISDN PRI  (Read 3930 times)
Offline cshah
« on: August 06, 2008, 07:23:57 PM »
All,
We have Genesys GVP (Standalone) in our environment and currently using ISDN PRI. We are considering the Genesys GVP (Stand along config with SIP Trunks from the Career).
Questions:
How many lines can run Gracefully in one WinTel  (Xeon Core 2 Duo, 2 CPU Server)? - SIP Config
How many lines can run Gracefully in one WinTel  (Xeon Core 2 Duo, 2 CPU Server)? - ISDN PRI CONFIG with Dialogic
Chirag
Offline CTIgem
Re: MAXIMUM Lines on a GVP-IP Standlone Box for SIP or ISDN PRI
« Reply #1 on: August 06, 2008, 07:59:33 PM »
Don't know about SIP but we have GVP 6.5 with Dialogic 96 ports and Xeon 4 cpu, it holds fine.
I believe dialogic is doing bulk of work.
RN
« Reply #2 on: August 10, 2008, 06:59:56 PM »
With a SIP configuration a single instance of IPCS can support upto 300 ports with DTMF and 200 ports with ASR\TTS.
cheers...rn
« Reply #3 on: August 10, 2008, 07:28:45 PM »
Detailed information about GVP capacity and sizing (Windows, Linux, TDM, SIP etc.) could be found in "Genesys 7 Hardware Sizing Guide".
Offline chilushah
« Reply #4 on: December 09, 2008, 06:58:20 PM »
Thanks guys!...
