" /> uui data to Genesys - Genesys CTI User Forum
Author Topic: uui data to Genesys  (Read 5188 times)
PandaIsDead
uui data to Genesys
« on: August 07, 2008, 07:36:24 AM »
I have a question about how uui-data is delivered to CTI softphone when it was attached by non-Genesys device. For example when call is transferred from IVR to softphone and IVR attaches uui-data data directly through AES.
Thank you in advance.
Offline Fra
Re: uui data to Genesys
« Reply #1 on: August 07, 2008, 08:10:27 AM »
TServer attaches uui data to the call as a KV pair whose key is UU_DATA. It also depends on the switch\Tserver version you are using, some old ones did not support it.
Fra
Marked as best answer by on Today at 09:05:21 PM
« Reply #2 on: August 07, 2008, 08:35:59 AM »
  • Undo Best Answer
  • UU_DATA :)
    Also, check out http://solutionsearch.genesyslab.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=137038&sliceId=1&docTypeID=DT_SOLUTION_1_1&dialogID=811361&stateId=0%200%20809587
