" /> TCP / UDP Ports - Genesys CTI User Forum
Author Topic: TCP / UDP Ports  (Read 7978 times)
Offline aflores
TCP / UDP Ports
« on: September 03, 2008, 08:04:06 PM »
Hello
Need information regarding ¿[move][/move]what are the tcp / udp ports and protocols used by Genesys Platform?.
Why do I need?.      Our client has implemented so many security rules that I think that it is given me some troubles. So the client ask me about the TCP / UDP ports and protocols used by Genesys, so he will allow this ports and protocols only for Genesys platform.
I will appreciated your help.
Regards.
AFlores
Offline postx
Re: TCP / UDP Ports
« Reply #1 on: September 03, 2008, 08:11:05 PM »
it depends on the different things:
- version of the GVP (f.e. GVP 7.2 EE doesn't need FTP, but the NE Version needs FTP for the Dispenser)
- GVP components you will install
- deployment of the components (less port usage if more components are installed on the same host)
Please tell which version you will use and how the deployment of the components will look like.
Regrads.
Offline aflores
Re: TCP / UDP Ports
« Reply #2 on: September 04, 2008, 03:05:00 PM »
Hi Postx.
Thanks for your reply.
Is´n there a general document whith all the ports and protocols used By Genesys, no matther the active aplications?.
Thats what I´m looking for.
regards
AFlores
Re: TCP / UDP Ports
« Reply #3 on: September 04, 2008, 04:02:18 PM »
Actually Alberto, when you install GVP or any other Genesys component you decide which ports to use. I believe on the checklist that is on deployment guide is a list of ports.
Offline eu4iacz
Re: TCP / UDP Ports
« Reply #4 on: September 05, 2008, 09:50:13 AM »
I also think that the port configuration depends mostly on your installation. Which means that Genesys uses ports that you entered when you installed the framework. There are recommended ports that you are prompted with during installation, but you can change it on your own.
[quote author=cavagnaro link=topic=3288.msg13620#msg13620 date=1220544138]
tony
Re: TCP / UDP Ports
« Reply #5 on: September 05, 2008, 03:04:59 PM »
...it might be easier to get your Network guys to list the TCP/IP>UDP ports already in use in your organization and avoid using them when installing Genesys components...?
Tony
Offline CTIgem
Re: TCP / UDP Ports
« Reply #6 on: September 08, 2008, 12:08:40 PM »
Genesys uses TCP mostly, I believe.
Please stay above 3000 range and you can assigned them as genesys ask for it.
I use 3000 range for framework, 5000 range for reporting 6000 range for management so forth.
And tell your security to open those ports for you.
Offline alan.mcintosh
Re: TCP / UDP Ports
« Reply #7 on: September 12, 2008, 03:14:49 AM »
You should also be aware that objects such as SIP Endpoint use a random high range of UDP ports.
It is also possible to force the endpoint to a fixed port. Please take a look at the depolyment guide for more information
Using tools such as wireshark will help you identify which ports are being used.
