" /> to create a log file with thresholds - Genesys CTI User Forum
Author Topic: to create a log file with thresholds  (Read 2687 times)
Stefano
« on: September 09, 2008, 03:09:19 PM »
hello, i am trying to create a log file (.txt) from a threshold applyed to the statistics objects, but it seems that the basic instructions don't work (open "Path" for append as #1: ecc. ecc.). Someone can help me?
thanks
Re: to create a log file with thresholds
« Reply #1 on: September 09, 2008, 08:01:51 PM »
  • You can search on google for tons of vb script examples.
    Offline S
    « Reply #2 on: September 10, 2008, 05:51:33 PM »
  • This one worked for me.
    But make sure TestCCPulse.txt already exists.
    Dim objFSO, objTextFile
    Dim sLogName
    sLogName="C:\TestCCPulse.txt"
    Set objFSO = CreateObject("Scripting.FileSystemObject")
    Set objTextFile = objFSO.OpenTextFile(sLogName,8,True)
    objTextFile.Write (Date())
    objTextFile.Write (" ")
    objTextFile.Write (Time())
    objTextFile.Write ("Agent ")
    objTextFile.Write (Threshold.CFGObjectID)
    objTextFile.Write (" There are ")
    objTextFile.Write (Threshold.StatValue)
    objTextFile.Write (" Agents logged in now.")
    objTextFile.WriteBlankLines(2)
    CCPulseNotifier.SetColor( Color.White )
    objTextFile.Close
    Set objFSO = Nothing
