" /> Help required !! Block manual calls in SJPhone ( Linux ) - Genesys CTI User Forum
Author Topic: Help required !! Block manual calls in SJPhone ( Linux )  (Read 3449 times)
SJPhone calls in Linux
« on: September 17, 2008, 05:35:48 AM »
Hi All,
        We r using SJPhone for dilaing in Linux systems. Can we block manual calls through sjphone so we can call only through Genesys Agent Desktop.... Help required !!  >:(
Re: Help required !! Block manual calls in SJPhone ( Linux )
« Reply #1 on: September 18, 2008, 02:11:17 AM »
Hum...and why do you want to block such feature? Can't see the difference...
mahesh
« Reply #2 on: September 18, 2008, 09:12:13 AM »
Yup I need to do so Coz... the callers r using those for calls and not dialing in dialer & disposing them.... Hope u can get it & help me out !!  :-\
Marked as best answer by on Today at 07:20:09 PM
Offline CTIgem
« Reply #3 on: September 18, 2008, 12:16:57 PM »
  • Undo Best Answer
  • Is it possible to set up some kind of access code?
