" /> Unable to install TServer with Config Wizard G6.1 - Genesys CTI User Forum
Author Topic: Unable to install TServer with Config Wizard G6.1  (Read 3095 times)
Hello, folks,
I was wondering if someone knew if it is possible to install a TServer with the wizard that comes along with G6. I tried installing a Meridian TServer by defining a switch, but when it prompts me what TServer I would like to use, wizard only has one choice TServer. I have never seen this type of template before. I have imported Meridian Template into CME, and strangely enough, I cannot find "TServer Template" under application templates. Am I doing something wrong???
Needless to say, I did not have any problems installing TServer for Meridian using Configuration Manager.
Any help would be greatly appreciated.
thanks,
Marked as best answer by on Today at 03:44:08 AM
Naoki
  • Undo Best Answer
  • No, you did not do anything wrong. We have a similar problem.
    Did anyone contact Genesys about it?
