" /> Unlock Config Mangr - Genesys CTI User Forum
Author Topic: Unlock Config Mangr  (Read 5774 times)
Configuration Manager
Unlock Config Mangr
« on: September 28, 2008, 04:42:51 AM »
Hi ,
      Someone has activated Read-Only mode in the configuration Mngr.. How can I take it off... I can't do anything !! Help Plz...  >:D
Offline barleycorn
Re: Unlock Config Mangr
« Reply #1 on: September 28, 2008, 05:12:28 AM »
  • First check that your dbserver is up and running - this may well be the issue, and also that config server has no connectivity issues.
    If that wasn't the problem, then log in to config manager using the "default" user and uncheck the "Read-Only Mode" from the Tools menu.
    mahesh
    « Reply #2 on: September 28, 2008, 05:32:36 AM »
  • Yeah.. Yesterday we made sql installation & now its ok ....
    Offline Marco64
    « Reply #3 on: September 29, 2008, 07:37:34 AM »
  • Also:
    If the Primary ConfServ goes off the Backup takes over but ConfServ will be in read only. To unlock this you will have to start the Primary again as primary.
    « Reply #4 on: September 29, 2008, 11:34:41 AM »
  • Really?
    Offline Fra
    « Reply #5 on: September 29, 2008, 01:25:23 PM »
  • mmh..which config server is the config manager connected to now?
    Offline kowari
    « Reply #6 on: September 30, 2008, 04:03:37 AM »
  • Also check you are not connecting to a configuration proxy server is you are using those.
