" /> Connection from CCPulse to a external D.B using Java Script - Genesys CTI User Forum
Author Topic: Connection from CCPulse to a external D.B using Java Script  (Read 4894 times)
Offline Mat
« on: October 06, 2008, 12:40:36 PM »
Hello
I need to connect from CCPulse whith an other data base, access or my sql for extract information and meke new formulas using the two information
Thank You
Offline Mat
Re: Connection from CCPulse to a external D.B using Java Script
« Reply #1 on: October 06, 2008, 02:30:02 PM »
La conexión la consigo con
wscript = new ActiveXObject("wscript.shell")
path = wscript.CurrentDirectory
mdb = path + "\\PruebaJava.mdb"
conn = new ActiveXObject("adodb.connection")
connString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source="+ mdb +";User Id=admin;Password="
conn.open(connString);
Select * from Clientes;
Ahora para hacer consultas o insertar datos?
Offline Mat
« Reply #2 on: October 06, 2008, 03:45:57 PM »
("SELECT Nombre FROM Clientes");
But when I´m going to create a new view a box said me that the sql snetence was removed
I need to show in CCPulse the actual agents logued in and the agent should be logued this are in my data base
Thank you
« Reply #3 on: October 06, 2008, 03:50:29 PM »
? And why not use StatServer tables instead?
Offline Mat
« Reply #4 on: October 07, 2008, 07:42:57 AM »
I need show in CCPulse the number of agent logged in and show our planification. Then I will create a thresold  if aggent loged < agent planificated.
Thank you
