" /> What version of Java for GIS 7.6 ??? - Genesys CTI User Forum
Author Topic: What version of Java for GIS 7.6 ???  (Read 4010 times)
Offline Sylvainsjc
« on: October 22, 2008, 06:04:00 PM »
All is in the title.
My GIS (SOAP standalone) apps won't start and i'm not very specialist with java apps (SDK, JDK, EE, SE)
At this time, i find is no logs files of the starting of the application.
I would like some helps to know what is the good Java choice for GIS
Thanks for your help
Re: What version of Java for GIS 7.6 ???
« Reply #1 on: October 22, 2008, 06:26:17 PM »
1.5.0.7 I believe...it is mentioned on the installation guide
Offline barleycorn
« Reply #2 on: October 22, 2008, 06:47:56 PM »
1.4 and 1.5 are both supported. Personally I've had some issues using 1.6 and try and steer clear of it until Genesys officially support it.
Offline Sylvainsjc
« Reply #3 on: October 23, 2008, 05:37:51 AM »
Thanks, i'll try this today
I also wanted to know the exact type of java because there are many versions and different editions
JRE ?
JDK ?
J2SE ?
J2EE ?
« Reply #4 on: October 23, 2008, 06:14:42 AM »
JRE
Offline Sylvainsjc
« Reply #5 on: October 23, 2008, 04:22:17 PM »
Well it's better with that version i found here : http://www.filehippo.com/download_java_runtime/1115/
First time i deploy GIS. It was difficult to find the reason of the problem because there wasn't any warning or logfile
Thanks for your helps.
« Reply #6 on: October 23, 2008, 04:31:11 PM »
??? Didn't I say that?
Offline Sylvainsjc
« Reply #7 on: October 23, 2008, 05:55:54 PM »
That the reason of my thanks cav
« Reply #8 on: October 23, 2008, 06:04:48 PM »
lol
