" /> IVR T server showing as service unavailable in SCI - Genesys CTI User Forum
Author Topic: IVR T server showing as service unavailable in SCI  (Read 7294 times)
Offline chandra
« on: November 05, 2008, 03:27:57 PM »
Last week I rebooted all of our servers, where I got this problem. All services in SCI seems to be started except the IVR t server. But this service seems to be started in windows services but sci shows this Service unavailable. Tried restarting LCA but this doesn't worked out. We are using 7.5 GVP and behind the switch configuration. Any ideas????
Chandra
Re: IVR T server showing as service unavailable in SCI
« Reply #1 on: November 05, 2008, 03:38:57 PM »
Hi Chandra,
Status "Service unavailable" means that IVR TServer is up and running but client (GVP in your case) isn't connected = IVR TServer isn't able to provide expected services.
You should check your GVP and logs of IVR TServer to find out a reason.
Offline chandra
« Reply #2 on: November 05, 2008, 06:28:15 PM »
Hi Renee,
Thanks for the quick reply. I didn;t find any significant information in the log. Shall i send you the log file? Please help me in this issue. :-\
Chandra
Offline ecki
« Reply #3 on: November 05, 2008, 08:36:16 PM »
Hi Chandra,
Yes post the I-server log first. Make sure that the logging is on the highest level.
e.
Offline chandra
« Reply #4 on: November 06, 2008, 03:36:43 PM »
Hi ecki,
Here is the log you requested.:-[
Chandra
Offline CTIgem
« Reply #5 on: November 07, 2008, 01:46:19 PM »
I don't see your GLI server and client in the log.
Please post your TserverIVR options.
Offline chandra
« Reply #6 on: November 10, 2008, 08:06:00 PM »
Hi CTI gem,
Here is the options of IVR t server as per your request.
Chandra
Offline chandra
« Reply #7 on: December 10, 2008, 03:04:15 PM »
As indicated out IVR t server status is unavailable in SCI. We have interaction routing that goes DB and all the data is logged in to DB. Now for some reason we are only getting blank rows for the calls.
When debugging the routing strategy, it looks good. Does this has any relation with the I serverclient? Please help me this trouble shooting.
When debugging strategy shows Entered calls=26, Calls routed=0 Calls abandoned=26. Please indicate a path for me, I was stuck in between. ???
Chandra
Offline jbobinsk
« Reply #8 on: December 10, 2008, 04:00:34 PM »
How many channels you are using, because you have only 1 license configured?
Regards
jbobinsk
Offline chandra
« Reply #9 on: December 10, 2008, 05:45:31 PM »
Hi jbobinsk,
We are using 24 ports in this environment. Probably 24 channels ;)
Chandra
Offline chandra
« Reply #10 on: December 11, 2008, 09:46:38 PM »
I just want to update you guys...The issue is resolved. When i have reviewed the CFA logs there is a message saying GQA is not running. I just restarted this manually and connection has been established. Now status is showing as started. :)
Thanks for the help. I like this forum and found very useful. I will keep posting.... :D
Chandra
