" /> RemoteConnection and Default path - Genesys CTI User Forum
Author Topic: RemoteConnection and Default path  (Read 4550 times)
Offline elwan
« on: November 06, 2008, 05:37:22 AM »
Hi all,
On the router logs, a particular call was delivered to an available agent. But after 15 seconds, there was a message EventRemoteConnectionFailed, the caller then received a disconnected message. Would that call go to the default number llisted on the ISCCAttributeExtensions 'DEFAULT#' ? I tried calling the number listed on the DEFAULT#, but it just went through ok to an agent, i didn't hear any disconnected message (number you are calling is not in service)
Thanks heaps.
Offline Adam G.
  • Still Gorgeous.......
Re: RemoteConnection and Default path
« Reply #1 on: November 07, 2008, 05:52:59 PM »
What was the Default number? Was it by any chance an ACD queue on your switch?
Offline elwan
« Reply #2 on: November 09, 2008, 10:18:28 PM »
The Default number is not an ACD queue of the switch. It is an NACD queue setup for a default scenario, it is not listed in Config Manager.
Offline elwan
« Reply #3 on: November 09, 2008, 10:31:18 PM »
the default number listed in the default destination option listed in the annex tab of the  routingpoint (ISCCAttributeLastTransferOriginationDN )
Below is the
ISCCAttributeUpdateRevision    1509229 [0017076d]
                'DEFAULT#'      '00292045166'
                'CUSTOMER_ID'  'C&C'
                'VQ'    'someVQ'
                'AGENT' 'someAgent'
                'PLACE' 'SomePlaceofDN'
                'DN'    '158509'
                'ACCESS'        '158509'
                'SWITCH'        'SomeSwitch'
                'NVQ'  1
                'TARGET'        'someAgentGroup@statserveer.GA'
        ISCCAttributeConnID    0649018fa72d6954
        ISCCAttributeOriginationDN      '0386614501'
        ISCCAttributeReferenceID        124597103 [076d336f]
        ISCCAttributeDestinationDN      '158509'
        ISCCAttributeCallDataXferType  RouteNoToken
        ISCCAttributeLastTransferHomeLocation  'ivr_tserver@ivrswitch'
        ISCCAttributeLastTransferConnID 0649018fa72d6954
        ISCCAttributeLastTransferOriginationDN  '0386614501'
        ISCCAttributeFirstTransferHomeLocation  'network_tserver@networkSwitch'
        ISCCAttributeFirstTransferConnID        0649018fa72d6954
        ISCCAttributeFirstTransferOriginationDN 'servicenumber'
Offline gustav
« Reply #4 on: November 10, 2008, 05:02:46 PM »
Sounds like a ISCC timeout (possibly from your external route points being busy).  What was the time between the ISCC Route Request and the ISCC timeout?  Check the TServer option under extrouter -> request-tout.  If this is 10 seconds, and your request-timeout events were 10 seconds appart you may need to look at configuring additional external route points, or changing the TServer setting to something larget.
From a data/targeting perspective, the agent will be found, selected and reserved, however the voice path will be unable to be paired.  Not 100% sure this is your issue, but something worth looking into.
Offline elwan
« Reply #5 on: November 10, 2008, 11:00:19 PM »
The agents sitting on SomeSwitch are outsourced to another country. SomeSwitch is an Avaya Switch, all other switches are Nortel.
Would it be a network latency or the ports running out perhaps, that's why it's timing out?
Request-timeout is 15 secs on the tserver, the route request and timeout is 15 secs.
Thank you very much.
Offline gustav
« Reply #6 on: November 11, 2008, 07:31:45 PM »
Network latency will only effect your data segment of the call.  I assume you are using a PSTN transfer connect (vs. Tie lines)?  15 seconds should be suffice for your tout setting, so I would recommend configuring additional external route points to handle to load.
Once a remote agent is selected, your external route points will be reserved for 15 seconds while waiting for a call, if your calls take 10-15 seconds to arrive you could easily use all availble external route points.
