" /> CCA, agent froup and agent reports - Genesys CTI User Forum
Author Topic: CCA, agent froup and agent reports  (Read 6732 times)
Lei Yein
Hi.
My customer want a report that list of all the agent but group by agent group. I had set up the agents and agent groups information in the cfg manager. Is anyone out there did this kind of reports before ?
cumi
  • Hi,
    the best is to use the ETL Object Tracking subsystem. You will have info in OBJ_TO_OBJ table, which agent to which group belongs....
    Lei Yein
    CCA, agent group and agent reports
  • I have check out the OBJ_TO_OBJ table, it is blank. How to set this up.
    (I have set up some agent groups with agents in CME)
    Lei Yein
  • I have set up the agent groups and respective agents in CME; Start and stop the processes, but still the OBJ_TO_OBJ table is still empty.
    eva
  • Is it possible for you to explain it a little bit more?
    eva
    Lei Yein
  • eva.
    the report sholud look like following...
    Talk Time Call answered ....
    Group_ABC
    Agent_1 XX:XX:XX XX
    Agent_2
    Agent_3
    Sub Total
    Agent Group_DEF
    Agent_4
    Agent_5
    Agent_6
    Sub Total
    Note : I have set up this relationship in the CME under AGENT GROUPS (group_ABC and group_DEF and respective agents), but I have no idea on how to retrieve the information out.
    eva
  • Hi,
    there are more ways to create a agent repot group by agent groups.
    1. You can create an Agent Report in the DMA.
    Select the Agent Group "Agent Group_ABC" instead of "All
    Agents".
    So you have a group by the Agent Group_ABC.
    2. You can work wiht Views in your DB.
    Create a View which select all Agents they belong to the Agent
    Group_ABC.
    select a.object_id,
    a.object_name,
    a.presentation_name,
    o.add_time as add_time_agent,
    o.delete_time as delete_time_agent,
    oto.add_time as add_time_group,
    oto.delete_time as delete_time_group
    from o_agent_day a, object o, obj_to_obj oto
    where a.object_id = oto.child_id AND
    o.object_id = oto.parent_id AND
    o.object_name in ('Agent Group_ABC')
    If it´s helpful, I can send you an Report where we have group agents by agent groups. (Brio)
    Eva
    cumi
  • it is in the CCA doc written, i don't know exactly...there are some additional options etl propertiesfile (trans_and_agg.properties).
