" /> Play announcement just before EventEstablished - Genesys CTI User Forum
Author Topic: Play announcement just before EventEstablished  (Read 4369 times)
Offline kip1
« on: November 18, 2008, 09:16:06 AM »
Is there anybody who did that and if so how.  ??? The Idea is to play voice prompt after which the call should be immediately picked up by agent.  :P
7.2
Avaya 8720.
IVR behind the Switch - Websphere VR for AIX - 4.2
The force will be with you......always.
Re: Play announcement just before EventEstablished
« Reply #1 on: November 18, 2008, 09:23:01 AM »
and what do you pretend to achieve with this?
Offline kip1
« Reply #2 on: November 18, 2008, 09:27:52 AM »
Skip the agent greeting. :P Not my idea.........
« Reply #3 on: November 18, 2008, 09:54:53 AM »
::) Well, again, sorry for the comparison but in Alcatel you do this without Genesys, IVR or anything, it is an internal function, maybe Nortel ACD has this option too? Have you asked your PBX guys?
Offline kip1
« Reply #4 on: November 18, 2008, 10:28:04 AM »
Nothing comes from them... :'(
Mike Kamlet
« Reply #5 on: November 18, 2008, 03:47:08 PM »
Depends on what type of announcement.
Whisper is supported on the Avaya (but that's only to the agent, not the customer)
If you're looking at an agent greeting app, you could build an IVR app that gets conferenced in to the agent.  (Avaya has such an application that we've been playing with in our lab).
M
Offline Cuore_2003
« Reply #6 on: November 18, 2008, 04:13:40 PM »
I not sure, but... you could set a VDN (RP). In the VDN must be configured a correct CTI vector with the corresponding "adjunct routing link", after that, plays an announcement (end the vector).
With the adjunct routing link correctly set, the call control is in Genesys.
After the message, just route the call to a selection block in your strategy.
Good luck!
