" /> wfm installation - Genesys CTI User Forum
Author Topic: wfm installation  (Read 4235 times)
rosy
wfm installation
« on: November 19, 2008, 07:17:22 PM »
hi,
is there any way that i can get a step by step installation of wfm 7.6
i had gone throuh the rough guide, its wonderful in giving the basic knowledge but im looking for a document that tells the installation process..
thanks for the help
Rosy
Re: wfm installation
« Reply #1 on: November 19, 2008, 07:38:52 PM »
WFM Deployment Guide?
rosy
« Reply #2 on: November 19, 2008, 07:40:58 PM »
s...
but im not satisfied with deployment guide provided by genesys ???
Rosy
Offline Tefleon
« Reply #3 on: November 19, 2008, 11:35:39 PM »
Which bit aren't you satisfied with?  Have you installed WFM before?
Marked as best answer by on May 03, 2025, 11:32:00 PM
« Reply #4 on: November 20, 2008, 06:00:42 AM »
  • Undo Best Answer
  • That could be the problem, reading the guides without trying to make it work can be hard to understand.
