" /> After Call Work State and SB - Genesys CTI User Forum
Author Topic: After Call Work State and SB  (Read 4489 times)
can someone please tell me how to be able to distinguish between Loggedin and not ready AND AfterCallWork?
I was trying to use custom stats definitions in Strategy Builder, by select CurrentStatus, AgentState, and AfterCallWork , but it would always return 0!!! Help! :)
Josee
  • I hope it will help, but I think that the Meridian switch do not support the AfterCallWork. Only the NotReadyForNextCall. You can see it in STATUS Table, Status field. You will see 8, but not 9.Or if you see it some times, the way it is used, you cannot do anything with it.For Genesys, after an Inbound Call, usually the agent is in state "after call work", but for the switch, he is ready or not.
    Bye
  • Josee,
    I got it to work. Sorry for not clarifying it earlier, but PBX is NEAX...
    As for the getting status, for some mysterious reason, I was able to get stats using the same line I tried to use before:
    Category: CurrentTime
    Subject: AgentStatus
    Actopm Mask: AfterCallWork
    Now, the question of the day is when should I be using DN Action? Agent Status? Also why can't I use CurrentState under the category section?
