" /> Upgrade of Config Server from 7.2 to 7.6 - Genesys CTI User Forum
Author Topic: Upgrade of Config Server from 7.2 to 7.6  (Read 3939 times)
Offline Scottyjohn
« on: November 26, 2008, 12:00:45 PM »
Hi all,
Just wondering for the listed confserv versions, if its a straight upgrade or is there any cfg DB work required?
Offline Steve
Re: Upgrade of Config Server from 7.2 to 7.6
« Reply #1 on: November 26, 2008, 12:28:18 PM »
You will need to run the Config Conversion Wizard to upgrade your database.
Offline Pranpong.S
« Reply #2 on: November 26, 2008, 04:57:59 PM »
From my experience. Between version 7.2 & 7.6 many different changed. I would suggest upgrade database first. And backup your strategy , DB Config , etc. Before your upgrade anyting.
« Reply #3 on: November 26, 2008, 05:01:15 PM »
No no, first is cfgserver, then DB (copy db, run wizard as told) then reconfigure to point to this new db, and then upgrade the rest of components. For some components like Multimedia you need to run also some SQL scripts in their own DBs.
Offline Steve
« Reply #4 on: November 27, 2008, 11:21:16 AM »
Don't forget the DB-Server. Do this before the Config Server.
« Reply #5 on: November 27, 2008, 02:07:43 PM »
:P yup, true.
