" /> config crash - Genesys CTI User Forum
Author Topic: config crash  (Read 4972 times)
sunitha
config crash
« on: December 02, 2008, 02:43:19 PM »
is there any possibility of config server getting crashed if i install webfolder in Internet explorer 5
suni
Offline CTIgem
Re: config crash
« Reply #1 on: December 02, 2008, 03:00:14 PM »
  • I don't see any relevance with directory structure.
    If you are using IE5, which version of OS are you running?
    sunitha
    Re: config crash
    « Reply #2 on: December 02, 2008, 03:01:08 PM »
  • windows 2000 advance server
    Offline CTIgem
    Re: config crash
    « Reply #3 on: December 02, 2008, 03:05:07 PM »
  • That should be ok. config server 7.x?
    Is there any reason you need to install it on the web folder?
    sunitha
    Re: config crash
    « Reply #4 on: December 02, 2008, 03:06:42 PM »
  • no its config server 6.5.
    actually config got crashed, and i see in the application log that just after 2 mins after config's crash theres an installation of webfolder.
    just wanted to confirm if this is the reason for the crash
    thanks for your help
    Offline CTIgem
    Re: config crash
    « Reply #5 on: December 02, 2008, 03:10:09 PM »
  • I wouldn't install it within web folder, if I were you.
