" /> Error code 56 ( Invalid connection ID ) - Genesys CTI User Forum
Author Topic: Error code 56 ( Invalid connection ID )  (Read 20922 times)
karthik
« on: December 03, 2008, 11:56:34 AM »
Hi All,
We are having  lot of calls which are default routing for a particular call type only. After checking the URS logs, I see a time out ( G3Cause 612 ) and the reason being error code 56 ( invalid connection id ).
Is this because of an mis-configuration on the trunk group ?? as the calls default routing are only for those calls where URS is selecting an agent at the othersite ( home site is cork and intersite is Austin in this case ). Here below is the log where we see the error.
Can you please suggest ?
received from 65200(EMEA_TSvr_P)hostname:32000(fd=11) message EventRouteUsed
AttributeCallState 22
AttributeThisQueue '54258'
AttributeNetworkCallID 1227785942
AttributeCallType 2
AttributeCallID 3388
AttributeConnID 007201a27a994639
AttributeCallUUID '005LDF0AI4CIT0BM251ES55AES004F63'
AttributeUserData [1696] 00 37 00 00..
'R_WO_NUM' 'W87435330'
'LBR_ORIG' '106:294'
'LBR_TS' '785980474'
'LBR_SNUM' '169'
'RRequestedSkills'(list)
'CollectedDigits' '87435330'
'R_START_TIME' '11:40:10'
'R_QUEUE_TIME' '11:40:10'
'R_FIRST_DNIS' '56503'
'R_Orig_VDN' '54258@EMEA_Avaya8710'
'CustomerSegment' 'default'
'ServiceType' 'ASCS_UK_English_Core'
'ServiceObjective' '30'
'R_CROSS_GEO' 'N'
'R_ACD_CALL' '1'
'R_EMERGENCY' 'N'
'R_EXT_DIALED' ''
'R_LOB_BU' 'ASCS'
'R_RONA' 'F'
'R_SUB' 'N/A'
'R_XFER_FLAG' 'N'
'R_CALL_TYPE' 'ASCS_UK_English_Core'
'LANGUAGE' 'English'
'DNIS' '56503'
'ANI' '44xxxxxxxxxxx'
'R_VDN' '54258'
'R_VQ' 'ASCS_UK_English_Core_VQ'
'R_ORIGIN' 'UK_Core'
'R_LANGUAGE_OPTION' 'N'
'R_FIRST_TARGET' '(AOSS_English>3 & ASCS_Core>1 & AOSS_GEO_EMEA>0 & AOSS_EMEA_Service>0 & ASCS_Active>0)'
'RTargetAgentGroup' '?:(AOSS_English>3 & ASCS_Core>1 & AOSS_GEO_EMEA>0 & AOSS_EMEA_Service>0 & ASCS_Active>0)'
'R_EXPANDED' '0'
'R_LAST_TARGET_AGENT' '232484653'
'R_Saved_RP' ''
'R_END_TIME' '11:40:11'
'R_LAST_TARGET' '(AOSS_English>3 & ASCS_Core>1 & AOSS_GEO_EMEA>0 & AOSS_EMEA_Service>0 & ASCS_Active>0)'
'RVQID' '01V57EH8A8CITB4C251ES5LAES0002EP'
'RTargetTypeSelected' '2'
'RTargetRuleSelected' ''
'RTargetObjectSelected' '?:(AOSS_English>3 & ASCS_Core>1 & AOSS_GEO_EMEA>0 & AOSS_EMEA_Service>0 & ASCS_Active>0)'
'RTargetObjSelDBID' ''
'RTargetAgentSelected' '232484653'
'RTargetPlaceSelected' '37280'
'RTenant' 'Resources'
'RStrategyName' 'AOSS_Main'
'RStrategyDBID' '1097'
'CBR-actual_volume' ''
'CBR-Interaction_cost' ''
'CBR-contract_DBIDs' ''
'CBR-IT-path_DBIDs' ''
'RRequestedSkillCombination' ''
'RTargetRequested' '?:Avalon > 99'
'PegTD' 1
'PegAG?:(AOSS_English>3 & ASCS_Core>1 & AOSS_GEO_EMEA>0 & AOSS_EMEA_Service>0 & ASCS_Active>0)' 1
'PegDOW' 1
AttributeDNIS '56503'
AttributeANI '442082181000'
AttributeCustomerID 'Resources'
AttributeNetworkDestDN 'AMR_Avaya8710::37280'
AttributeThisDN '54258'
AttributeThisDNRole 2
AttributeOtherDN '442082181000'
AttributeOtherDNRole 1
AttributeThirdPartyDN '52031'
AttributeThirdPartyDNRole 2
AttributeExtensions [35] 00 02 01 00..
'G3Cause' 612
'UCID' bin: 00 03 0D 3C.. (len=8)
AttributeTimeinSecs 1227786011 (11:40:11)
AttributeTimeinuSecs 478131
AttributeEventSequenceNumber 0000000000080651
11:40:11.481_T_I_007201a27a994639 [14:0c] EventRouteUsed(strange) is received for tserver EMEA_IRL_ORK_TSvr_P[EMEA_Avaya8710] (this dn=54258)
    _T_I_007201a27a994639 [14:0a] del DN (EMEA_IRL_ORK_TSvr_P[EMEA__Avaya8710] 54258) (ref.id=866)
    _T_W_007201a27a994639 [14:0a] there is no DNs for call, activate delayed selfdestruction
received from 65200(EMEA_IRL_ORK_TSvr_P)hostname:32000(fd=11) message EventDiverted
11:40:11.481_T_I_007201a27a994639 [14:0c] EventDiverted is received for tserver EMEA_IRL_ORK_TSvr_P[EMEA__Avaya8710] (this dn=54258)
received from 65200(EMEA_TSvr_P)hostname:32000(fd=11) message EventError
(Invalid connection id)
AttributeErrorCode 56
AttributeReferenceID 866
AttributeTimeinuSecs 494788
AttributeEventSequenceNumber 0000000000080654
11:40:11.495_T_E_ [14:0c] EventError is received for tserver EMEA_IRL_ORK_TSvr_P[EMEA_Avaya8710] - Invalid connection id
11:40:11.495_A_E_007201a27a994639 [14:32] <-----------ERROR
11:40:11.495_I_I_007201a27a994639 [09:05] >>>>>>>>>>>>resume interpretator(0)
    _I_E_007201a27a994639 [09:05] error in strategy: 0013 Remote error
    _I_I_007201a27a994639 [09:04] ASSIGN: routeError(LOCAL) <- STRING: 56 Invalid connection id
    _I_I_007201a27a994639 [09:04] ASSIGN: AlarmString(LOCAL) <- STRING: ERROR-Q1: For RouteCall in C_Try_To_Route, Received Error Code: 56 ConnId:007201a27a994639
    _I_I_007201a27a994639 [07:3f] get data from cfglist(AOSS_Global) item ErrorAction, key ErrorCodes result: 56:Alarm|610:Print
    _I_I_007201a27a994639 [09:04] ASSIGN: ErrorActions(LOCAL) <- STRING: 56:Alarm|610:Print
    _I_I_007201a27a994639 [09:04] ASSIGN: ActError(LOCAL) <- STRING: Alarm
11:40:11.495 Std 22010 Strategy Error: Strategy Error: C_Try_To_Route_Q1: ERROR-Q1: For RouteCall in C_Try_To_Route, Received Error Code: 56 ConnId:007201a27a994639
11:40:11.495 Int 22000 ERROR-Q1: For RouteCall in C_Try_To_Route, Received Error Code: 56 ConnId:007201a27a994639
    _I_I_007201a27a994639 [09:04] ASSIGN: Status(LOCAL) <- STRING: error
    _I_I_007201a27a994639 [09:04] ASSIGN: CurrentQTime(LOCAL) <- INTEGER: 767
Cheers
Karthik
« Last Edit: December 03, 2008, 07:57:16 PM by Wyn »
Offline jbobinsk
Re: Error code 56 ( Invalid connection ID )
« Reply #1 on: December 03, 2008, 01:45:50 PM »
  • I've seen such message before and it was caused by two step transfer to VDN, and Event Route Request was generated on consult call, and Request Route Call was sent to original call, because in the mean time EventPartyChanged appeared.
    The way of resolving such problem was to postpone adjunct in vector (on avaya), to ensure that Event RouteRequest will be sent to Inbound call not to consult call.
    Regards
    jbobinsk
    mike kamlet
    « Reply #2 on: December 03, 2008, 02:25:39 PM »
  • Another way to "wait" for the transfer to complete is to use the URS option route-consult-call = false
    This way if an IVR is transferring a call to a route point (IVR on the same switch), URS will wait for PartyChange before executing the strategy.
    And as with all URS options, this can be set on the route point itself
    « Reply #3 on: December 03, 2008, 02:47:19 PM »
  • Hi,
    it seems to me that this is a problem with your delay - you are transferring a call then is actually being completed while you are doing so, thus the error.
    Add delay in your vector or make Genesys SuspendForEvent with EventPartyChanged :)
    And... I would suggest removing ANI from your post as well as hostnames maybe? :)
    Offline Fra
    « Reply #4 on: December 03, 2008, 04:12:50 PM »
  • Hi,
    as the others said, you are receiving an EventError to your RequestRouteCall cause the call has already been routed out; the switch has taken control of the call cause of a timeout on the vector of the VDN the call was queuing on.
    Fra
    Offline Adam G.
    • Still Gorgeous.......
    « Reply #5 on: December 03, 2008, 04:59:02 PM »
  • [quote author=victor link=topic=3636.msg15433#msg15433 date=1228315639]
    It looks like you've saved your DDI number as ANI. tut tut
    ;D
    karthik
    « Reply #6 on: December 03, 2008, 05:18:14 PM »
  • thanks Guys for your suggestion. I would definately ask the switch guys to postpone adjunct route for a few more secs in vector and I will keep you updated.
    Thanks again
    Karthik
    karthik
    « Reply #7 on: December 03, 2008, 05:23:49 PM »
  • Hi Tony Tillyer, Pavel, victor
    Can anyone one of you please delete this post as i forgot to rename  or remove the host names from the log attached.
    Cheers
    Karthik
    Offline Adam G.
    « Reply #8 on: December 03, 2008, 07:58:09 PM »
  • Hostnames and DDI are now atomised  ;D
    karthik
    « Reply #9 on: December 03, 2008, 10:15:52 PM »
  • Thanks buddy. I need a small clarification. the above scenario where URS has selected an agent from a different switch or site ( Austin in this case ) this call would be an ISCC call, isnt it ? is it compulsory that we use an ERP to route this call or can this be routed through RP also ?
    Am asking too many questions, I know :( am relatively new to Genesys and am all alone in the site, finding it a bit tough to learn as well as support.
    Cheers
    Karthik
