" /> config server crashed - Genesys CTI User Forum
Author Topic: config server crashed  (Read 5263 times)
suntiha
« on: December 04, 2008, 02:25:24 PM »
Hi there,
Application popup: confserv.exe - Application Error : The instruction at "0x004265d6" referenced memory at "0x00000000". The memory could not be "read".
the above event is captured from event log, and this happend just few minutes before our configserver crashed.
could you guyz pls help us in explaining how is these both linked
thanks for your help
sunitha
Offline Fra
Re: config server crashed
« Reply #1 on: December 04, 2008, 02:52:57 PM »
we can't say anything from it, you need to post the confserv log file and the version you are running.
sunitha
« Reply #2 on: December 04, 2008, 03:03:01 PM »
hi ,
we dont have any information for that particular period.
it was only mentioned that config backup has taken over the main server.
version : 6.5
operating system : windows 2000
« Reply #3 on: December 04, 2008, 10:27:03 PM »
Is there a noc file in the application folder?
Marked as best answer by on Today at 09:23:02 AM
Offline Daimonas
  • There's a fish in every bowl.
« Reply #4 on: December 05, 2008, 12:47:52 AM »
  • Undo Best Answer
  • Maybe this will help, found it on Genesys support website.
    [quote][b]Problem Description[/b]
    Worked for several months. User is logged onto CME when crashing. Problem happening for the last 3 weeks. Unable to determine what changed.
    Error: "The instruction at "0x5f401a8e" referenced memory at "0x00000004". The memory could not be "written"."
    Error2: "The instruction at "0x00000000" referenced memory at "0x00000000". The memory could not be "read"."
    [b]Solution [/b]
    sent latest GA of Configuration Manager [/quote]
    So check the version of CME your clients are using.
    Offline Adam G.
    • Still Gorgeous.......
    « Reply #5 on: December 05, 2008, 07:46:45 AM »
    Was anyone using CME at at the time? If so what were they doing?
