" /> Messages to and fro T-server - Genesys CTI User Forum
Author Topic: Messages to and fro T-server  (Read 6960 times)
karthik
« on: December 11, 2008, 01:27:19 PM »
Hi Guys,
Do you know how do we find if there are any gaps in Messaging between T-Server and AES ? We are having a few issues where we see no messaging from switch for a few secs, we came to know when we analysed a few conn ids which were default routed.
But I wanted to how do we know if thats happening again, say for a particular time. Do we have any key words to grep and check all messages were proper. Here below is the messaging from T-server logs. how do we read them ?
@12:03:33.0718 [<<] 08 00 00 27 08 02 82 22 62 96 1C 1F 91 A1 1C 02 01 02 02 01 95 40 14 08 02 81 9C 10 02 37 D9 70 06 80 2A 2A 2A 2A 2A 96 47 01 8C
@12:05:06.9567 [>>] 08 00 00 24 08 02 50 B6 64 96 1C 1C 91 A1 19 02 01 03 02 01 8C 40 11 96 49 06 81 36 34 35 34 B9 49 06 83 31 35 31 35 B5
Cheers
Karthik
Offline Fra
Re: Messages to and fro T-server
« Reply #1 on: December 11, 2008, 02:52:27 PM »
[quote author=karthik link=topic=3656.msg15575#msg15575 date=1229002039]
You should use the Avaya Asai protocol reference guide.
Fra
Offline Fra
« Reply #2 on: December 11, 2008, 03:58:40 PM »
The first message is a report about an  "invalid number", whereas the second is a Status Query of a DN.
karthik
« Reply #3 on: December 11, 2008, 08:52:36 PM »
Thanks buddy, I have download a few docs from avaya.
By the way, which digit did you use for identifying the type of facility invoke ?
Offline chandra
« Reply #4 on: December 13, 2008, 09:55:40 PM »
Hi Karthik,
Can you post your further steps in your trouble shooting, as we too are experiencing the same problem....
Chandra
Offline Fra
« Reply #5 on: December 17, 2008, 10:56:36 AM »
[quote author=karthik link=topic=3656.msg15583#msg15583 date=1229028756]
For the first message, 0x62 is the message type, 0x9c is the cause value; for the second message, 0x64 is the message type, 0x81 the domain type.
Fra
Marked as best answer by on November 05, 2025, 01:50:19 AM
karthik
« Reply #6 on: December 19, 2008, 01:23:29 PM »
  • Undo Best Answer
  • Hi Fra,
    Thanks. and I did go through some ASAI protocol and code guide. Learning day by day :)
    And Chandra,
    The issue was identified to be a switch side issue. CLAN for AES  server is connected to is running on older Firmware , this should be upgraded and can cause some CTI connectivity issues if the firmware remains on older versions.
    I would suggest you to check the firmware and make sure you have the right and latest version.
    Cheers
    KArthik
    Offline chandra
    « Reply #7 on: December 19, 2008, 05:49:17 PM »
    Hi Karthik and fra,
    Thanks for the information. I will look in this direction.
    Chandra
    karthik
    « Reply #8 on: December 19, 2008, 10:04:31 PM »
    Please check the clan firmware version if it is 21 or below, possible suggestion would be to upgrade it to 24 which has fix for this issue, and latest version is 26.
    am not an expert, but just a beginner to Genesys, but i thought i could share what i have come across, i hope this would be useful.
    Cheers
    Karthik
