" /> JRUN and ICC 6.1 - Genesys CTI User Forum
Author Topic: JRUN and ICC 6.1  (Read 5421 times)
zewt
JRUN and ICC 6.1
Hi
Did anyone manage to make ICC 6.1 to run in JRUN 3.1 distributed environment?
Regards
Marked as best answer by on August 03, 2025, 01:09:51 AM
JRUN and ICC 6.1
  • Undo Best Answer
  • We are evaluating right now. It seems to be working, but there are aa lot of billions of little tiny things you need to do to get it to work... :(
    zewt
    JRUN and ICC 6.1
    My Hipbone server is up and running but no matter what i set, i can only corowse internal websites. i had set the business rule to false.
    Vic, you have any idea what i need to change?
    Thanks.
    zewt
    JRUN and ICC 6.1
    Found out that current Hipbone server version does not support proxy server. The hipbone server must have direct connection to the internet.
    JRUN and ICC 6.1
    Zewt,
    do you have a simple procedure you could share as to how to install Hipbone Server and the rest of the callback? I cannot get the hibpone server to work.
    Zewt
    JRUN and ICC 6.1
    Do you have the copy of ICC6.1 migration guide download from Genesys Website?
