" /> CCpulse Historical view - disabled - Genesys CTI User Forum
Author Topic: CCpulse Historical view - disabled  (Read 4440 times)
Offline Gururaj S
« on: January 29, 2009, 01:10:06 PM »
Hi To All,
I have installed CCPulse and real time views are working fine.
I have also installed ODS and Datamart and Database initialization is complete for Datamart.
But when i open CCPulse, and right click on any object, the menu option "Historical View" is greyed out.
I have tried suggestions from support site but none could fix the problem.
Regards,
Gururaj S
Offline CTIgem
Re: CCpulse Historical view - disabled
« Reply #1 on: January 29, 2009, 01:16:19 PM »
Do you have database access point set up to point at datamart?
Offline Gururaj S
« Reply #2 on: January 29, 2009, 01:20:23 PM »
Hi CTIgem,
Yes.. I have installed DBserver and there is a DAP for Datamart.
Regards
« Reply #3 on: January 29, 2009, 04:47:30 PM »
And does CCPulse has connection to DataMart?
tony
« Reply #4 on: January 29, 2009, 05:20:52 PM »
...and as a next step, you will also need to define statistics within CCPulse that you want to emulate, from the Historical Statistics available in your Datamart...
In this way, you create a link between the Real-Time and Historical Statistics, within CCPulse...
Tony
