" /> CCPulse call stuck? - Genesys CTI User Forum
Author Topic: CCPulse call stuck?  (Read 10305 times)
Eugene Khoo
CCPulse call stuck?
I've one isolated case,happened only once with a customer with CC Pulse.
There was a inbound call, appeared in Current Waiting calls in the VDN queue but it remained stuck for about 2 days until statserver was restarted. The wait time was over 22 hours. I couldn't duplicate this though. I thought the calls would automatically be cleared after something like 10 hours?
Any ideas what happened and how to resolve it without taking statserver down?
scott
CCPulse call stuck?
I had the same problem but I had to restart statserver also :). Hopefully, somebody has resolved this here.
CCPulse call stuck?
What version of stat server are we talking about here?
We had the same problem with 5.1.075 and I do not think we were able to resolve it. The only way we could get rid of the problem is by deleting the statserv.000 file and rebooting the statserver.
Please tell me that the more recent versions are not having the same problem!
Marked as best answer by on October 16, 2025, 10:39:49 PM
CCPulse call stuck?
  • Undo Best Answer
  • Someone told me once that you can use STATMAN to fix the problem; however, I looked and I looked, and all I could do was reread SCE config and disconnect all the clients... No stats reset function though!( at least not in 5.0.002)
    I looked into G6.1 and statman version there is still 5.0.002, so I doubt that it is possible.
    scott
    CCPulse call stuck?
    I was using version 6.1 and still, I experienced this problem.
    Tony
    CCPulse call stuck?
    We've had this problem for a long time. We have been able to successfully reproduce it by interupting the IP connection between the StatServer and the TServer. We did not have this problem when the StatServer and TServer resided on the same server.
    So this is usually caused by a network failure in which a message from Tserver to Statserver was lost.
    Hope this helps..
    Nick
    CCPulse call stuck?
    We have experienced the same problem. We believe that the TServer was not receiving a 'call released' event from the Alcatel CSTA and so the call persisted in the stats until StatServer was restarted. This was almost certainly due to network issues. The CSTA does not repeatedly send the event until acknowledged and so if TServer misses it, it is lost for good.
    We are currently looking for a way to drop the call without restarting StatServer. Will update if/when we have a solution...
    cumi
    CCPulse call stuck?
    We also experienced this problem a few times. The solution for this is: ask the Genesys support for their 'unsupported' softphone. You can connect with this tool to TServer and send him e.g. EventDiverted with the ConnID of the stucked call....It helps and you doesn't have to restart servers in production.....
    scott
    CCPulse call stuck?
    Hi, there. Thanks to Cumi for the info. I have used Cumu advice and I used Dynamic Phone to send an Event Released and it worked :)
    Calum
    CCPulse call stuck?
    « Reply #9 on: January 01, 1970, 12:00:00 AM »
    What if you don't have the connid because the logs have not been turned on? Anyother work arounds?
    CCPulse call stuck?
    « Reply #10 on: January 01, 1970, 12:00:00 AM »
    Well, if you have QINFO table you can fish it out of there.
    Or, if you really know what you are doing, you can do it with a statman tool that is enclosed with Stat Server.
    Calum
    CCPulse call stuck?
    « Reply #11 on: January 01, 1970, 12:00:00 AM »
    How do you use statman? Where can I get some info...
