" /> About WFM 6.1 Message Server - Genesys CTI User Forum
Author Topic: About WFM 6.1 Message Server  (Read 3066 times)
Devrim
What is the Message Server, and how can i install and
configure it? There is no brief information in the
Genesys documentation.
Thank you and regards,
  • Message Server is used by the Management Layer.
    Genesys document says:
    Message Server provides centralized processing and storage of every application's maintenance events. Events are stored as log records in the Log Database where they are available for further centralized processing. Message Server also checks for log events configured to trigger alarms. If a match is detected, the alarm is sent
    to Solution Control Server for immediate processing.
    You can find more about it by reading 61fr_refml document enclosed with 61 Framework, or just ask here :)
    To put it simply, Message Server does the following:
    store all the messages from the applications into a database (a simplified version of a log that you can then see with SCI)
    when error occurs, tell SCS to do something about it
    used by strategy builder in outbound solution to collect real ime statistics for call flow monitoring.
    With WFM, you would use it to probably do ... good question :) I was under the impression that Genesys insists that we install management layer no matter what if using G6.1... I wonder if we can do without all of that...
    Have you tried using WFM WITHOUT Message Server?
    Talking about WFM, how did you find it in 6.1? We have used 5.1.6 and 6.0 and so far, the results of our evaluation were rather dismal. It seems like there was something there, but yet, the packaging and manmachine interface was really something that reminded me of my 8th grade science fair project :)
