" /> UUI length field - Genesys CTI User Forum
Author Topic: UUI length field  (Read 5050 times)
UUI length field
Does anyone know what is the length of UUI field? In Genesys and in PBX?
Marked as best answer by on Yesterday at 11:35:42 PM
Gnom
UUI length field
  • Undo Best Answer
  • G3 Tserver supports up to 128 bytes
    UUI length field
    Ok, here is what I have found:
    even though TServer supports up to 128 bytes, since even with Genesys 6.1 only ASAI 3 is supported, you only get 32 bytes worth of UUI... With ASAI 4 it goes to 64 bytes. Go figure :)
