" /> Co Browsing in Genesys 7.2 - Genesys CTI User Forum
Author Topic: Co Browsing in Genesys 7.2  (Read 13149 times)
Doubt
« on: March 17, 2009, 06:24:14 AM »
Is there a possibilty to implement Co Browsing in Genesys 7.2 without installing KANA Response Live Server?
Re: Co Browsing in Genesys 7.2
« Reply #1 on: March 17, 2009, 09:35:36 AM »
  • No
    Doubt
    « Reply #2 on: March 17, 2009, 10:00:40 AM »
  • Thanks for your reply.
    I installed KANA and Co Browser server, when i test the kana installtion,in login page when i click go i am getting the below error.
    The requested resource (/CONAV/HTD/Default/login/sslDisabled.thtml) is not available.
    Any idea what cud be the reason???
    « Reply #3 on: March 17, 2009, 10:52:19 AM »
  • Hi,
    CoBrowse requires SSL to work properly. Have you enabled it? Is KANA Tomcat up and running?
    If you don't have SSL certificate you can disable that pre-requisite in KANA Administrator. Check the KANA documentation for more info (search for work "SSL relaxer"). It is highly recommended to use SSL for production deployment due security.
    Doubt
    « Reply #4 on: March 17, 2009, 11:04:23 AM »
  • Hi,
      I have a valid SSL certiifcate, also the tomcat is up and running. Then also i am getting this error. Dont know why... Kindly help ....
    « Reply #5 on: March 17, 2009, 05:01:55 PM »
  • Hi,
    Ok. In that case it is either Tomcat or Apache configuration error. Try to access the page https://<tomcat host name or IP>:<tomcat port>/CONAV/HTD/Default/login/sslDisabled.thtml directly. If you can access it then it is Apache configuration issue and you should modify the file "mod_jk.conf" and add following line
        JkMount /CONAV/* ajp13 [i]<--- I assume that worker name is ajp13[/i]
    If you can't access the page then it is Tomcat issue. You should look into the file "server.xml" in Tomcat's "conf" directory and check that the path (docBase) for the path CONAV is correct.
    Doubt
    « Reply #6 on: March 18, 2009, 05:09:18 AM »
  • Hi,
          There are two conf  folders in my machine
    1. c:/kana/tomcat/conf
    2. c:/program files/apachetomcatfoundation/conf
    In the server.xml (in c:/kana/tomcat/conf)  i have the below specified path
    KANA Response Live Context -->
    <Context path="/CONAV" docBase="../../hbroot/" reloadable="false" useNaming="false"/>
    But i dont have any specification for CONAV in server.xml(the one in c:/program files/apachetomcatfoundation/conf).
    Kindly let me know which one do i have to use .Also whether the specified path is correct or not ?
    Doubt
    « Reply #7 on: March 18, 2009, 12:14:10 PM »
  • Somebody pls clarify this...
    « Reply #8 on: March 18, 2009, 03:23:01 PM »
  • Hi,
    It's hard say which Tomcat is the right one if you have more running on the same host but my assumption is that the one you're looking for is located in C:\Kana\Tomcat.
    Running multiple instances of Tomcat on one host is possible but requires proper configuration. Check that your Tomcat instances are not using the same TCP/IP ports. You can find info about configured ports in server.xml files - look for the tag "Connector"
    Doubt
    « Reply #9 on: March 18, 2009, 05:19:04 PM »
  • Thanks for ur reply..
    Both are using different ports . Kindly clarify whether the following path is correct or not
    « Reply #10 on: March 18, 2009, 05:28:10 PM »
  • [quote]Both are using different ports[/quote]
    Have you checked AJP/13 ports as well? Apache communicates with Tomcat using AJP not HTTP protocol.
    [quote]Kindly clarify whether the following path is correct or not
    <Context path="/CONAV" docBase="../../hbroot/" reloadable="false" useNaming="false"/>[/quote]
    Check for existence of the folder "hbroot" on the same level as Tomcat folder is. Tree should look like:
    /KANA
    |__ /hbroot
    |__ /Tomcat
          |__/conf
                |__ server.xml
    Doubt
    « Reply #11 on: March 19, 2009, 11:37:56 AM »
  • Hi,
      I checked tomcat is using AJP protocol only . Also the worker name is AJP 13 only.
    The folder structure is also similar to what u have mentioned.
    But still it is giving me the issue.
    Can u pls tell me how to point the installed tomcat to my kana tomcat.??
    Also, similar to KANA is there any other co browser technology provider in the market???
    Kindly clarify this...
    « Reply #12 on: March 19, 2009, 06:30:42 PM »
  • [quote]Try to access the page https://<tomcat host name or IP>:<tomcat port>/CONAV/HTD/Default/login/sslDisabled.thtml directly[/quote]
    Have you tried? Result of this test could tell us where the problem is - Tomcat or Apache.
    Doubt
    « Reply #13 on: March 20, 2009, 10:05:22 AM »
  • Hi,
          The problem is resolved now. The problem was with tomcat. There was one more webserver called Apache 2 which was there in my services. I stopped Apache service and started Responselive,Apache 2 services. After that it is working fine. I am able to co browse.
    Thanks a lot for ur suport.
