" /> URS warm standby - Genesys CTI User Forum
Author Topic: URS warm standby  (Read 3338 times)
Offline CTIgem
URS warm standby
« on: March 17, 2009, 12:16:27 PM »
After the upgrade to 7.6, URS warm standby seems not working properly.
I'm getting .......
I'm not seeing the message about going into Backup mode..
Router High Availability Mode is turned off
08:09:55.325_C_W_ [02:02] can't initialize management layer
Open LCALayer on port=4999
LCA Library version 7.5.000.05
08:09:55.325_C_C_ [14:04] router is forced into active mode
Applications OK
Offline Fra
Re: URS warm standby
« Reply #1 on: March 17, 2009, 02:19:00 PM »
You should post the full log from start-up; however my guess is that your URS is looking for an HA license but can't find it.
Fra
« Reply #2 on: March 18, 2009, 11:41:52 AM »
What does LCA and SCS logs say?
Offline cmcshane
« Reply #3 on: March 18, 2009, 03:01:44 PM »
Did you upgrade from version 6.5 ? If so did you update your HA licenses to 7 ?
Offline CTIgem
« Reply #4 on: March 19, 2009, 11:40:32 AM »
Had to get the new license file, warm standby option is not free anymore like back in 6.5 days...
