" /> There is not event for a consult call! - Genesys CTI User Forum
Author Topic: There is not event for a consult call!  (Read 3490 times)
CJ
Does anyone know a workaround for the Meridian link not reporting that a cosultation call being put on hold? Thanks, CJ
Victor
  • CJ,
    I think you are using a rather old TServer version. Upgrade, my friend. 5.1.5837 has rlsconcult tv option which would take care of this particular problem.
    Tell me if it did not solve your problem.
    Cheers,
