" /> WFM : - Genesys CTI User Forum
Author Topic: WFM :  (Read 4513 times)
Offline lekie
WFM :
« on: March 24, 2009, 04:39:14 PM »
Daer All,
I got this error "Error[66]Internal scheduling engine error" when I was building schedule. Have some one use to face the error like this?
Best Regards,
Lekie
tony
Re: WFM :
« Reply #1 on: March 24, 2009, 07:14:42 PM »
Check to see if you have a single Exception entered twice in the same Schedule...?
« Last Edit: March 24, 2009, 07:18:28 PM by Tony Tillyer »
Offline lekie
Re: WFM :
« Reply #2 on: March 25, 2009, 03:39:57 AM »
Dear All,
I did not put the exception before build schedule.
Thank you,
Lek
tony
Re: WFM :
« Reply #3 on: March 25, 2009, 07:57:04 AM »
Could you tell us what version(s) of WfM Software you are running?
Tony
Offline PeterJ
Re: WFM :
« Reply #4 on: March 25, 2009, 02:30:54 PM »
Could you describe the scenario you use and what parameters you use / set during schedule build?
Peter
Offline lekie
Re: WFM :
« Reply #5 on: March 25, 2009, 03:59:15 PM »
Dear All,
WFM Client is 7.6.0
WFM CCPulse is 7.5.0
WFM DAB is 7.6.0
WFM builder is 7.6.0
WFM Data Aggregator is 7.6.0
WFM Server is 7.6.0
WFM Web is 7.6.000.18
Supervisor do forcasting for the call volumn and staff, and do scheduling after that.
Supercisor choosed Shuffel Agent and builde schedule.
Thank you in advance,
Lekie
