" /> Major difference between SIP server 7.6.0.62 and 7.6.0.73 - Genesys CTI User Forum
Author Topic: Major difference between SIP server 7.6.0.62 and 7.6.0.73  (Read 3552 times)
wanttoknow
« on: April 28, 2009, 06:42:34 AM »
Does anybody on this forum know the major differences between these two versions? What happens if we don't upgrade?
Offline Timur Karimov
Re: Major difference between SIP server 7.6.0.62 and 7.6.0.73
« Reply #1 on: April 28, 2009, 07:25:38 AM »
If u have access to genesys support site u can read about all changes from 7.6.0.62 to 7.6.0.73 (and latest one 7.6.0.76) in release notes.
Genereal, most differenses what only in latest version Genesys fix same ugly bags and provide same hones futures. And don't forget about first sysadmins rule - It's work? Well don't touch it! =)))
WBR Timur
Marked as best answer by on Today at 02:15:08 AM
Offline Dionysis
The release notes should show the differences, but realistically if you don't upgrade, it will keep working as it does now.
Generally... no need to upgrade unless there is something specific in the release notes that you need.
