" /> Brio 6.x and Oracle 10g/11g... - Genesys CTI User Forum
Author Topic: Brio 6.x and Oracle 10g/11g...  (Read 4180 times)
tony
« on: April 28, 2009, 12:18:01 PM »
Just considering moving from 9i to either Oracle 10g or 11g and wondered if anyone had got this far with Brio/BES 6.x ([b]not [/b] Hyperion) and run across any "compatability" errors.
I seem to remember, when upgrading to 9i, that we got some "ORA" errors messages in Brio Designer, where 9i had (by design) truncated Tables and Views that didn't happen in previous versions of Oracle.
Thanks for any input/pointers!
Tony
Offline CTIgem
Re: Brio 6.x and Oracle 10g/11g...
« Reply #1 on: April 29, 2009, 01:00:50 PM »
  • We are at 10g now and still using Brio 6.x.
    Been running for sometime now, about 2 yrs.
    tony
    « Reply #2 on: April 29, 2009, 02:01:41 PM »
  • Thanks - I am trying to avoid running something like 35 template reports 3 or 4 times over in our DEV environment, just to prove that 10g will not cause any issues for Brio 6.x...  ::)
    Tony
    Offline catanirex
    « Reply #3 on: April 29, 2009, 03:42:40 PM »
  • Hi,
    Long time ago I received this answer from support regarding Brio and Oracle 9:
    "Brio 6.6 does not support Oracle 9.2. However, it is possible to use this database through the Oracle 8.1.7 client."
    But since Brio 6.6 isnt supported any longer, I guess that you can try to use it on your own risk.
    Good luck!
